Hi Everyone,
Hope you’re all safe and well. So I’ve finally started attacking my ebay purchase from two years ago. My Lotus Plus 2S appears to be an August 1971, Type 50 , ID # 0179N, Big Valve power plant, (standard compression), Federal example. (Early Plus2 S130, 4 speed per Andy Graham at the Registry.) Powerplant is original, Engine u/24-911. This was sold as a complete, but very unfinished, partial restoration project.
The car needs a lot of everything. So I thank you advance for any help, suggestions or recommendations.
I’ve decided to start with the tired electrics. (I know my limitations so I willl leave the engine and chassis work to the experts at Flying Circus British Restoration.)
-The dash is quite nice, and I’ve purchased both the engine bay loom and dash wiring loom and have spent many hours hashing thru connections using the old harness and a poster sized enlargement print of the schematic . I took out the old dash harness to help me sort this mess. It has an alternator and 3 fuseboxes in Engine Bay.
In any case I hope you all can help me. I’ve decoded a lot of stuff and made decent progress but remain stuck in a few areas. Thanks in advance for your help, suggestions and guidance.
The car is gutted inside and is a fiberglass bathtub. However the car is complete and I have most of the stuff in boxes. Anyway back to the harnesses. I’ve compiled a list and any insight is appreciated.
First I need some help identifying some things. Is the photo below a seat belt buzzer? Can’t see a pn. I have square flasher units on dash so I don’t think that’s it. It has one wire coming off terminal 4 on the old ignition switch.
Mystery toggle switch: I have two rockers for FOG and SPOT, but have no clue what this toggle does. Can’t find it on the print. Color code is purple/blue and black. My guess is it has something to do with the headlamps/headlamp relay. It does appear to be OEM, and not a mod of any sort.
The Coil has three wires all yellow and white that need connection. I don’t know if all three are used. The schematic is no help. There is no way to differentiate them for connection to positive or negative terminals. I have a “CVI” Current driven tach, and still am not sure what post (+ or -) on the coil provides the signal. I’ve read a lot of articles, and have completely confused myself finding an answer.
It also seems like the sidelamp microswitches and headlamp microswitches were never installed/connected to the old harness. These connections were taped over. I am not even sure the switches exist. Is this a common thing to bypass them? Are they really needed?
Also have a bear of a time wiring the hazard switch. I was considering using 036M 6271R as replacement switch from Ray D. Enterprises. Once again the wiring schematic was not a big help in this arena, as the folks at British Wiring made some wiring color substitutions of their own, that do not follow the print or the old harness wiring. The connections I have to work with are the following:
-Two green/red stripe wires
-Two green white stripe wires
-Yellow/black stripe from flasher unit
Not sure if I am missing any others
On the forum many have said “Run the dash out of the car.” Aside from basic continuity checks- are there any other methods out there to check it before install? Is there a recommendation I could follow.
Thanks all for the help. This has been a big job and quite a puzzle. Any PHOTOS are also really appreciated.
I can’t help but wonder if this thing is going to burn to the ground once I flip on the wipers…
(maybe I just won’t flip on the wipers…)
