Superflex Bushes
Hi all, I have got a set of Superflex bushes from Sue Miller to put in my Plus 2. Is the assembly lubricant used to lubricate the bush when it goes into the suspension arm or for when the inner metal bush goes into the body??? Or both???
Al Cowan
I believe it’s for the inner bushing.
Hi I put the nylon bush into the A frame dry and then used the lubricant to help ease the metal insert into the bush.
This worked for me.
Dave
I fitted a set of these on the front of my sprint but due to the "end caps " on the bushes they are wider than the rubber bushes which only allowed the nylocks to come flush with the end of the bolt it should be 2 full turns exposed & my mot tester did not want to pass it. I turned the nuts down a bit or you could use 1/2 nuts. This was 2 years ago Sue Miller may have changed them since. Not done the back ones yet but i saw mick doing front bushes a few years ago & he lubricated the bush to get it into the wishbone
Ian
Thanks for all your help. I put them in tonight, hot water to get them into the wishbone and then lubricant to get the metal inner into the bush,
Al Cowan
