Sound Insulation
Hi All, anyone out there have any successful experience of sound insulating a +2S? If so - where are the most effective areas to treat and what materials would you recommend?
Thanks in advance.
Wayne
Wayne, I don’t know if this will apply to your situation. This is one solution I used. When I was restoring my S3 Elan coupe I used a paint-on sound proofing from a company in CA. US called Quiet Solutions. quietsolution.com/ Go to (Quiet car) Three coats reduced the DP level by 20. That is what they claimed. I have no way to confirm it but it is much quieter. I painted the entire interior, including the roof, doors and trunk. Then installed the carpet pad and carpet. It kills the sound vibrations from passing thru the fiberglass. If I had a radio I could hear it. Just an option, it worked for me as I had everything out of the car, including the dash. I can still hear the webers when I excelerate.
Have fun, Sarto
You might try this item on the dreaded “eBay” !! 330023407590 or indeed this search on the same web site !
motors.search.ebay.co.uk/sound-d … sacatZ9800
Hope this helps you out
Here’s what Corvette C5 people use:
http://tinyurl.com/nx92p
eDead http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=54
eDead v3 Latex Polymer Gallon $50
Coverage Area : Roughly 50Sq. Ft. Per Gallon
Extremely High Temperature Adhesive
Sticks To Factory Plastic Panels
Sticks To Factory Metals
Self Adhesive
Adheres to OEM Sound Deadening
McMaster-Carr mcmaster-carr.com
Vibration Damping Compound
Brush, spray, or trowel on this water-based elastomer to control vibration on metal surfaces on auto components. It air dries within 3 to 4 hours leaving a tough and flexible finish. Temperature range is -20? to +120? F. Color is beige.
Size Coverage Each
5-gal. Pail 270 sq. ft. $77.22
[paceproducts.com/peel-n-seal.htmPeel ‘n’ Seal
Pressure Sensitive Synthetic Rubberized Tape
Provides mass. When laid in strips accross large flat panels, reduces drumming, resonance, and other panel-transmitted noise. Floors, bulkheads, roof, doors, etc.
PEEL-N-SEAL is a lightweight, resilient, rubber-like adhesive
PEEL-N-SEAL comes with a paper backing. It fits in most inaccessible places and can be painted immediately after application
Use inside or out. Indefinite storage life. Covers 30 lineal feet per roll.
Available in 6" width. Comes in black.
Reflectix http://tinyurl.com/na6aa
Reflective insulation for use in a crawl space, attic, wall, metal buildings, and post and frame structures. Fiber free, environmentally safe, easy to install, and it is lightweight. No protective gear needed to install. Reflects 97% of radiant energy.
? Reflects 97 percent of radiant energy.
? Nontoxic/noncarcinogenic.
? Does not require protective gear to install.
? Does not compress, collapse or disintegrate
? Class A Class 1 fire rating
? Durable and lightweight
? Lowers heating and cooling costs year round.
? Easy to install.
? Not affected by moisture or humidity.
3M Spray Adhesive ?#93?
If you would like to discuss this further, email me offline. I’ve done it; I guess a 3-6 dB drop in overall noise and heat is cut remarkably.
GP
