Relay location 68 Plus 2 SE
Hi - I have recently bought a 68 Plus 2 that has a few issues.
The wiring has been “modified” sometime in the past, and various electrical equipment is not working correctly - horns, indicators, panel lights etc - and so I am looking to repair/replace as required.
I have a workshop manual which is nicely detailed, but it doesn’t really show the specific location of, for example, the horn relay.
Has anyone got a diagram of where the relays/fuses are located please?
TIA :slight_smile:
'68 Plus 2 - hope this helps :smiley:
Fuse position on a 69 +2 S is as per the photos attached. Pre the ‘S’ model was slightly different, but the horn relay position was the same.
This should be the fuse box. Pull the plastic cover off.
Relays are as follows:-
Red:- Headlamp flasher relay
Green:- Headlamp flasher
Blue:- Horn relay
Brian.
Ah, that’s great - thank you all very much. :slight_smile:
