(See picture below - worth 2k of my words!)
I have just re-assembled my rear suspension (+2) and fitted new bolts to the inner wishbone mountings. The previous ones were in reasonable condition but did not give 2 pitches clear of the Nylocs when tightened.
The official workshop manual notes that the bolts should be fitted with the heads innermost. This is difficult to fit with the shorter bolts and impossible (without using a greek screwdriver) with my longer bolts, hence I fitted the bolts with their heads outermost.
I cannot see that this should make a difference. Greatest loading on the bolts fitted as recommended will be when the wishbone moves upwards at the outboard end and it could be reasoned that there is a minute chance that the nut could be undone - but unlikely I think. The reverse is true with the bolts mounted with the heads on the outside.
Anyone see me having a problem with this arrangement?
On the Elan [perhaps the same for the +2] if you don’t fit the bolts with the heads facing inwards you can’t remove them when the body is back on!
I ditto that, I made that mistake
Doesn’t seem to be a problem with the +2: all this work is being done with the body on.
The reason the bolts should be fitted with the nuts innermost is down to the correct engineering practice of holding the bolt whilst turning the nut when doing the fastener up. Fitting the other way round means the bolt has to be turned to tighten it, this will prevent the correct torque being applied as potentially the bolt will twist over its length and therefore the correct torque cannnot be applied.
Bear in mind that all of the suspension arm bolts should only be torqued up when the suspension is loaded (and therefore with the body in place, )so that the lower arms are horizontal/parallel to the ground, it makes sense to fit the bolts during the production process to allow for the required access to the nuts for the final tightening to the correct torque.
However in a maintenance situation, it isn’t always possible to achieve this! You have two options, one is to cut down your new bolts and struggle to fit them the ‘correct’ way round, or do as you have done and get on with enjoying your car!
I like most have done mine the latter way when restoring my chassis(body off) with an eye/thought to future maintenance along with copious amounts of anti sieze compound.
regards
It looks like the bushes are of the Poly type so there is no need to torque up with the suspension in the normal ride height.
