Rear Hubs
Hi all
I have a set of rear wheels which ran on an Elan set up whose centres are on or around 4" (between 101 and 102mm).
The hubs I have are 3 3/4".
Were any hubs drilled for that size of bolt on wheel and if so, which model?
Gavin
Hi Gavin,
You are correct, the standard PCD is 3 3/4 in.
On eBay, martingf sells adapters to convert the 3 3/4 in PCD to 100 mm. Look at item 250047862014 or search for “Triumph Spitfire GT6 TR7 TR8 Lotus Alloy Wheel Adapters” if the listing has expired.
Good luck.
David
1968 36/7988
