My Plus 2 experience with the Coolex aluminum wide radiator and remote oil filter might not be exactly the same in your Elan. That said, FWIW….
The encouraging news is I didn’t need to clearance the radiator mounts as the oil filter AN flexible hoses fitted easily on each side of car nose. I did cover the hoses with dense foam pipe wrap from the home improvement store to prevent any rubbing.
I had a bit more fussing to route the vent hose from the front of the cam cover to a catch bottle in the nose. Also used foam pipe wrap at the radiator mount. I located the catch bottle pretty much in the centre of the nose as in my car there was a sort of drain hole in the base of the nose that accumulated a drain plug screwed in to the bottom of the catch can.
I located a conical K&N style air filter on the left (driver’s) side of the nose. Best to locate this first as it takes the most room. It is well ahead of the catch can. As mentioned earlier, I think I used 3” diameter trunking to the air filter as that is all I could fit past the radiator mounts.
My spin-on oil filter mounts into the nose on the right (passenger) side. I used some aluminum strip to form a simple bracket. I had already mounted one lateral piece of aluminum U-channel material across the nose cone to hold a couple of small PIAA driving lights (basically used as Daytime Running Lights). The U-channel attaches to the top of the oil filter bracket; without this additional support I would really worry about cracking the fibreglass trying to move a stuck filter canister. I also used the same bracket to mount a small air horn.
My electric pod motor is on the right (driver’s) side with its own independent mount. My fail safe system only needs one pod motor.
It all fits but definitely needs a bit of thought.
HTH Hoping for better luck on the rest of the project. Good idea to wait on the remote filter due to all that is going on, but I have found limited access to the AN nipple on the exhaust side of the engine. This might make doing the oil filter a bit more difficult. Much easier with the engine and radiator out of the way.
I had some leaking at the exhaust side nipple. As John installed it I don’t know details of the threads, etc. I was able to get it to seal by tightening. Not sure if this area had to be tapped into the block or is usually a blanking plug?
Another suggestion would be to pressure test the hose fittings and nipples in the oil filter bracket before finalizing the bracket attachment. I found they needed enough torque to seal that the oil filter mount needed to be stabilized while tightening; relying on the fibreglass was going to damage things.
All the best with the project. The car is going to be awesome!
Stu in Calgary
