オイルフィルター参照番号
Hi can anyone give me a company ref number of a good quality oil filter for the elan EG Fram champion or man.
G
From the Golden Gate Lotus Club parts interchange page:
Spin on oil filter - Fram PH2870A, AC PF34, Purolator PL20252 or L20252, Wix 51327, K&N HP-2005
Paper cartridge type Fram CH2804
G
Your local parts supplier can probably supply if you know whether its a spin off or not, stock item for various Fords. Dan has also given you the part numbers you need, try here
Tony
I am using Mahle’s OC21, simply because that’s what the engine builder (promotor) fitted during build, so I’ll stick with that one.
Thanks guys I will check these out
