| Class | 111 |
| Number | 1972/15 |
| Type | All Models |
| Date | 07.08.1972 |
| Title: | Weatherproofing |
| Reason: | To advise Service Personnel of where water leaks may occur and showing the points which we check in Production before a car is delivered. |
| Action: | From the enclosed sketches, it can be seen immediately where water leaks may occur (or recur), and it is suggested that where complaints are received of this nature, the appropriate sketch be studied and the necessary rectification action taken. It should be noted, that the majority of these points are covered in Section V (Body) of the Workshop Manual, as are the recommended sealants to be used. |
