| Class | 111 |
| Number | 1973/09 |
| Type | +2S 130 |
| Date | 02.04.73 |
| Title: | Roof Refinishing |
| Reason: | To advise Dealer personnel of the recommended method of refinishing the roof panel . |
| Parts Required: | A050 B 6220V - Acrylic Blend Clear A505 B 6221V - Retarder Thinner |
| Action: |
- Areas to be refinished should be flatted to remove gloss, etc . Use a 360 grade paper, wet.
- Dry the area, and tack rag to remove surface dust.
- Spray polyester gel coat to match the base colour.
- Mix 5 oz (143 grm) flake to 2 pints (1 .14 litres; 2.4 US pints) of Acrylic Blend Clear. Spray a thin even coat of the flake mixture over the base colour. Flash off 30 minutes at 68F. (20C.)
- Spray light dust coats of Acrylic Blend Clear. Cure for 8 hours at 68F. ( 20 C.)
- Flat, and polish.
