| Action: |
This information supersedes that already published in Section V (Fuel System) of the Workshop Manuals. Two float assemblies are currently used in Dellorto carburetters, these being:- Float assy. 7298-01 (A036 E 6061Z) used in Type DHLA 40 (non-emission) carburetor.
- Float assy. 7298-02 (A036 E 6062Z) used in Type DHLA-E (emission) carburetor.
The float levels, measured at B on the illustration, are:- Type DHLA. 40 14.5 to 15 mm. ’ A’
- Type DHLA-E 40 16.5 to 17 mm. ‘A’
To check the float level. the whole assembly is held with the floats hanging down and needle valve lightly closed. To adjust the float level, the arms should be bent at ‘C’ on the i 1 lustration . |
