Class = 111
Number = 1972/14
Type = Elan Sprint & 2S 130
Date = 07.08.1972
| Title: |
Dellorto Carburetters |
| Reason: |
To introduce to the Parts Department, a full list of Parts for the above carburetters, which are available as replacements. |
| Action: |
- Add the parts listed on this Bulletin to Section E (Engine) of both the Elan and 2 Service Parts List. New pages will be issued as soon as possible.
- Raise Stock Cards as necessary.
- Make allocation in Stocking Area to accommodate the parts.
| Parts Required: |
Full list of parts involved are as shown below and on the following pages. The ‘Key No.’ refers to the illustration printed overleaf. |
| Key No. |
Part No. |
Description |
Qty. |
Q026 S 0710W |
Carburetter, front (40 DHLA) |
1 |
Q026 S 0711W |
Carburetter, rear (40 DHLA) |
1 |
| 1 |
A036 E 6040Z |
Choke (33 mm.) |
2 |
| 2 |
A036 E6059Z |
Auxiliary venturi |
2 |
| 3 |
A036 E 6042Z |
Jet, main (120) |
2 |
| 4 |
A036 E 6048Z |
Jet, idling(50 |
2 |
| 5 |
A036 E 6057Z |
Jet, pump (45) |
2 |
| 6 |
A036 E 6051Z |
Jet, starting (70) |
1 |
| 7 |
A036 E 6053Z |
Emulsion tube, main |
2 |
| 8 |
A036 E 6055Z |
Emulsion tube, starting |
1 |
| 9 |
A036 E 6045Z |
Jet, main air corrector (130) |
2 |
| 10 |
A036 E 6050Z |
Jet, adling air corrector |
2 |
| 11 |
A036 E 6060Z |
Needle valve |
1 |
| 12 |
A036 E 6061Z |
Float |
1 |
| 13 |
A036 E 6063Z |
Screw, securing choke cable |
1 |
| 14 |
A036 E 6064Z |
Support, choke cable |
1 |
| 15 |
A036 E 6065Z |
Plug, starting valve scat |
1 |
| 16 |
A036 E 6066Z |
Spring, starting valve |
1 |
| 17 |
A036 E 6067Z |
Starting valve |
1 |
| 18 |
A036 E 6068Z |
Cover, float chamber |
1 |
| 19 |
A036 E 6069Z |
Gasket, float chamber cover |
1 |
| 20 |
A036 E 6070Z |
Gasket ’ needle valve |
1 |
| 21 |
A036 E 6071Z |
Screw, jet cover fixing |
2 |
| 22 |
A036 E 6072Z |
Washer, spring |
2 |
| 23 |
A036 E 6073Z |
Jet cover |
1 |
| 24 |
A036 E 6074Z |
Screw, securing float chamber cover |
4 |
| 25 |
A036 E 6075Z |
Gasket, jetcover |
1 |
| 26 |
A036 E 6076Z |
Washer, spring |
4 |
| 27 |
A036 E 6077Z |
Control shaft, starting valve |
4 |
| 28 |
A036 E 6078Z |
Washer, spring |
1 |
| 29 |
A036 E 6079Z |
Plug, starting shaft |
1 |
| 30 |
A036 E 6080Z |
Control lever, starting valve |
1 |
| 31 |
A036 E 6081Z |
Return spring, starting lever |
1 |
| 32 |
A036 E 6082Z |
Bush, starting lever return spring |
1 |
| 33 |
A036 E 6083Z |
Washer, spring |
1 |
| 34 |
A036 E 6084Z |
Nut |
1 |
| 35 |
A036 E 6085Z |
Gasket, banjo union (fuel pipe) |
1 |
| 36 |
A036 E 6086Z |
Float pin |
1 |
| 37 |
A036 E 6087Z |
Union, banjo (fuel pipe)-rear carburetter |
1 |
| 38 |
A036 E 6088Z |
Filter, petrol |
1 |
| 39 |
A036 E 6089Z |
Gasket, plug securing banjo |
1 |
| 40 |
A036 E 6090Z |
Plug, banjo |
1 |
| 41 |
A036 E 6091Z |
Union ’ banjo (fuel pipe)-front carburetter |
1 |
| 42 |
A036 E 6092Z |
Lever, throttle control |
1 |
| 43 |
A036 E 6093Z |
Screw, adjusting |
1 |
| 44 |
A036 E 6094Z |
Spring, adjusting screw |
2 |
| 45 |
A036 E 6095Z |
Washer, plain |
3 |
| 46 |
A036 E 6096Z |
Gasket |
3 |
| 47 |
A036 E 6097Z |
Screw, idling mixture adjustment |
2 |
| 48 |
A036 E 6098Z |
Spring, screw |
2 |
| 49 |
A036 E 6099Z |
Plug, pump jet |
2 |
| 50 |
A036 E 61OOZ |
Gasket, pump jet |
2 |
| 51 |
A036 E 6101Z |
Gasket, pump jet |
2 |
| 52 |
A036 E 6102Z |
Plug, progression holes inspection |
2 |
| 53 |
A036 E 6103Z |
Plug, pressure connection |
2 |
| 54 |
A036 E 6104Z |
Plug, delivery valve sect |
2 |
| 55 |
A036 E 6105Z |
Stuffing, delivery valve |
2 |
| 56 |
A036 E 6106Z |
Outlet valve |
2 |
| 57 |
A036 E 6107Z |
Gasket |
2 |
| 58 |
A036 E 6108Z |
Nut |
2 |
| 59 |
A036 E 6109Z |
Plate, retaining |
2 |
| 60 |
A036 E 611OZ |
Spacer |
1 |
| 61 |
A036 E 6111Z |
Washer, distance |
2 |
| 62 |
A036 E 6112Z |
Ball bearing |
2 |
| 63 |
A036 E 6113Z |
Spring, pump diaphragm |
1 |
| 64 |
A036 E 6114Z |
Pump diaphragm |
1 |
| 65 |
A036 E 6115Z |
Washer |
1 |
| 66 |
A036 E 6116Z |
Spring, pump rod |
1 |
| 67 |
A036 E 6117Z |
Nut |
1 |
| 68 |
A036 E 6118Z |
Nut |
1 |
| 69 |
A036 E 6119Z |
Pump cover |
1 |
| 70 |
A036 E 6120Z |
Washer, spring |
4 |
| 71 |
A036 E 6121Z |
Screw, pump cover fixing |
4 |
| 72 |
A036 E 6122Z |
Gasket, pump body |
1 |
| 73 |
A036 E 6123Z |
Pump body |
1 |
| 74 |
A036 E 6124Z |
Inlet valve |
1 |
| 75 |
A036 E 6125Z |
Gasket, inlet valve |
1 |
| 76 |
A036 E 6161Z |
Screw, auxiliary venturi fixing |
2 |
| 77 |
A036 E 6127Z |
Nut, fixing screw |
2 |
| 78 |
A036 E 6128Z |
Stud |
2 |
| 79 |
A036 E 6129Z |
Spring, throttle shaft return |
1 |
| 80 |
A036 E 6130Z |
Screw, pump control lever fixing |
1 |
| 81 |
A036 E 6131Z |
Rod, lever and pump control |
1 |
| 82 |
A036 E 6132Z |
Throttle |
2 |
| 83 |
A036 E 6133Z |
Screw, throttle fixing |
4 |
| 84 |
A036 E 6134Z |
Washer, spring |
4 |
| 85 |
A036 E 6135Z |
Screw, pump body fixing |
4 |
| 86 |
A036 E 6136Z |
Shaft, throttle |
1 |
| 87 |
A036 E 6137Z |
Pin, split |
1 |
| 88 |
A036 E 6138Z |
Pin, control lever |
1 |
| 89 |
A036 E 6139Z |
Spring, pin |
1 |
| 90 |
A036 E 6140Z |
Control Lever |
1 |
| 91 |
A036 E 6141Z |
Screw, control lever |
1 |
| 92 |
A036 E 6142Z |
Washer, spring |
1 |
| 93 |
A036 E 6143Z |
Screw, fixing |
1 |
| 94 |
A036 E 6144Z |
Rod |
1 |
| 95 |
A036 E 6145Z |
Washer, plain |
1 |
| 96 |
A036 E 6146Z |
Screw, securing cable |
1 |
| 97 |
A036 E 6147Z |
Gasket, |
4 |
| 98 |
A036 E 6148Z |
Screw, horn retaining |
4 |
| 99 |
A036 E 6149Z |
Nut |
8 |
| 100 |
A036 E 6150Z |
Washer, spring |
8 |
| 101 |
A036 E 6151Z |
Air horn |
4 |
A036 E 6163W |
Gasket kit-comprising the following gaskets |
AR |
A036 E 6069Z |
Float chamber cover gasket |
1 |
A036 E 6070Z |
Needle valve gasket |
1 |
A036 E 6075Z |
Jet cover gasket |
1 |
A036 E 6085Z |
Banjo union gasket |
1 |
A036 E 6089Z |
Banjo union plug gasket |
1 |
A036 E 6100Z |
Pump jet gasket |
2 |
A036 E 6101Z |
Pump jet plug gasket |
2 |
A036 E 6107Z |
Idling air jet gasket |
2 |
A036 E 6122Z |
Pump body gasket |
1 |
A036 E 6147Z |
Carburetters to manifold gasket |
4 |
A074 E 0464Z |
Spring, throttle return. |
1 |
