Lotus Elan 5 speed gearbox for sale Uk
I have decided to sell my Lotus Elan / Plus2 five speed gearbox.
The box has been stripped and rebuilt with new parts as required, it is in excellent, ready to install condition. Details of the rebuild can be checked with the gearbox professional I used, if required.
It has had replacement bearings, new gear synchros and gaskets.
It is just the gearbox on its own, no bell housing, propshaft, gearbox or chassis bracket. I may be able to include a 5 speed gearbox lever and Speedo drive, if the full price is paid,
@ £1500.00.
(Pictures to be added when I can figure out how to do it!)
l10tus
when you are posting just click the up arrow on the top line of your message and it will start the process so you can select the file, assuming you are on a PC
Tony
Tony, unfortunately not on pc!
l10tus
Could you download the pics onto a PC and then send?
Tony
Tony, Pictures added for reference, the bell housing is not included as I borrowed it from a friend and unfortunately, he doesn’t want to sell it.
Hi there, Do you know if the 4 speed and 5 speed bellhousings and other mounting bits are the same?
The Lotus 5 speed has a unique bell housing and tail housing for that matter. Basically you cannot fit a 4 speed box to a Lotus 5 speed bell and tail housing. The mounting bracket will fit, but it needs to be tuened through 180degrees and the mounting holes modified/added. Speedo drive etc will fit, gear lever won’t.
mark
