I posted some pics of my car when I got it late last year. Here it is again after a good of cleaning session earlier today. It’s amazing how well it’s come up with just a bit of care, attention and elbow grease … although to be fair the pictures are a bit flattering.
It’s just been fitted with a TTR shocks and springs (front and rear), a TTR front roll bar and a cage. It now drives as well as it looks. If only I could get rid of the pesky hesitation where it ‘clears its throat’ when pulling away…
Your car is without a doubt one of the most beautiful Elans I have ever seen and I have seen quite a few of them. No doubt it’s better than it looked when it left the factory!
Thanks Frank, but the pictures really are very flattering. I think I just caught the light well. The body is very definitely less than perfect in the ‘flesh’ … but for some reason the pictures don’t show the blemishes at all. I know they are there, but to others I am sure the pics make the car look perfect.
I think you would be a little disappointed if you saw it first hand as it has some very obvious cracks, dings, splits and micro blistering!
Best viewed from 10 yards or through a lense would be my description!
Hi James … The Elan does look great …and with its body imperfections ... sounds like its one you can really enjoy !
As for that “Pesky Hesitation” … apart from the obvious plugs , points, leads , ignition timing , carbs etc ., needing to be in good order ..... I find that , due to not having the 60s/70s nectar fuel anymore .... that a substantial increase in the progression ( idle ) jet ( way above original spec ) , makes a massive difference , when set-up right .
There`s nothing more annoying than , driving a delightfully responsive little Elan , being bogged down on silly progression … and having to punch your way through it .
Get the right “Progression Jet” … it`s an easy job ( even a moron like me can do it ; ) … and You can have a really lovely idle , with super sweet light throttle response and acceleration .
That`s just my experience … but also , if you are very heavy with the right boot … it does naturally gulp a lot of air initially down those long inlet tracts on take off ( hence encouraging hesitancy …despite the accelerator pump assistance) … so easy ( like everything on the elan ) with the throttle , is all that is required .
Jimbo, great pictures. I know what you mean. My car can also look pretty good in photographs, but it does have blemishes, chips and cracks here and there.
I also have the TTR suspension and TTR roll bar fitted in mine so our two cars are remarkably similar, hesitation on initial acceleration included!
Thanks for the feedback. Is it worth looking at additives in addition to playing with the progression jet? I run the car on Super unleaded but have not tried additives.
Zarelan, our cars look like twins. At least they will do when I get around to fitting the side indicators. Any chance you could measure the position of yours so I know where to drill?
Yes a fuel additive is definitely good … and best to stick with it , setting the Car up appropriately .
Today , the regular quick burn 95/97/98 unleaded is , rather weak for an Elan .
Like a lot of people , I use Millers VSP plus , to up the octane by 2 ( & gives valve seat protection if not converted to unleaded ) … which runs like velvet …and improves the economy to help offset the cost .
There is also Millers CVL ( plus 3 octane ) but that doesn`t give much protection , if you need it .
Remember , the Elan was designed to fly on 5 star 101 octane … so , better the fuel better the drive : ) .
Thanks for the reply. I will get some Miller and give it a go!
Having said that, I drove the car again today and problem is not actually on the initial pick up. It’s between 2000 and 2500 rpm right at the point where the car gives a loud WHHHAAAARRRPPP.
Below that point the car is very smooth, and the same at over 2500 rpm. If you are really light on the throttle you can ‘stroke’ it through without it coughing, but any kind of moderate throttle opening produces a hiccup/cough that clears as the revs rise.
I guess it could be the cam profile? Or is it a case of “they all do that sir”?
I hear what you are saying and I agree in terms of looks, but I drive on Dual Carriageways a lot so I think side repeators are a wise option. I’d rather have an Elan with ugly indicators than have someone not realise I am pulling out.
You’ve got my four year old telling everyone that his dad’s “little red sportscar” has a brother or sister, as he’s seen it on the Internet. Perhaps we should arrange a ‘family’ reunion?
As for the coughing , it could be several things … but definitely shouldn`t do that , if everything is O.K .
I should systematically work through the basics and go through everything … treat it to the new leads , plugs , points etc., doing one job at a time .
Make sure valve clearances , Carb`s and ignition timing etc is good for “Your car” ( static timing may not be as the manual anymore ) … then You can tune it .
It shouldnt be the cams , if they are regular sprint ones .... and the fact You can stroke through it , suggests a weak/blocked progression is also playing its part ( it can affect up the rev` range higher than you think when under load ) , as you are compensating by stroking the accelerator jets .
Its probably a combination of "off Tuneness" .... but can be corrected ... and then Youll think you are in a different Car and will never want to part with it ; ) .
James - Very nice car I have a bahama yellow (acquired taste) and have all TTR suspension fitted. One thing I noticed that is the same as mine is the SD roll cage but no foam or head restraints. A scrutineer told me that if I drove this on the road without a helmet and got in an accident the impact of my head on the steel roll cage would kill me or a passenger instantly. I have a little one and got the Safety Devices padding. I notice on the later roll cages they now have a fixing for a head pad.
All these beautiful cars…and mines still a bitsa. To help me along my way can one of you guys with an original Sprint post a few photographs of the engine bay so that i can see where all the gubbins goes, like wiring, hoses, relays, vac pipes, oil pressure tap off etc etc. I’m just about to get the body back and drop it on so will be hanging the bits on soon.
Thanks a bunch
Bob
Real nice pictures of your engine. One suggestion. You probably already know this, but for those of you who don’t, the leads are coming out of your distributor at 12:00. You can easily adjust them to come out at 10:00 so they will more easily route up between the intake manifold by pulling the distributor straight out (the rotor will rotate due to the bevel gear) and then rotating the shaft 60 degrees clockwise from the position it stopped at before pushing the distributor back into the block. Then, it’s just a matter of timing the distributor. The leads on my distributor come out at 9:00 because they are routed around the back of the engine into the spark plug valley. Hope this is somewhat useful information.
