holley.com/products/drivetr … ts/RM-4055
Anyone use these?
Anyone use these?
The Ford 2.3 has the two upper bolt holes significantly higher than the 1500/1600 engines. Probably could just cut it down and re-drill, though.
ah, I guess its for the newer 2.3 but doesn’t specify.
Very doable. I know it was discussed here, with pictures, using the factory version of this bellhousing
when fitting a T5. The top two ears were cut off and relocated.
