JC - Brakes - Rear +2
Item Lotus # All +2 +2 FED +2S +2S FED +2S 130 RHD LHD Description Change Point
Notes
Bulletin Reference
050J6002 1 Caliper - Rear LH
050J6003 1 Caliper - Rear RH
1 036J6035 4 Piston
2 036J6032 4 Pin - Pad Retaining
3 036J6033 4 Clip - Pad Retaining
4 036J6051 AR Repair Kit
5 036J6034 2 Cap - Bleed Screw
6 036J6036 2 Lever - Clamping, Outer
7 036J6037 2 Lever - Clamping, Inner
8 036J6038 4 Pin, Pivot - Handbrake to Caliper
9 036J6039 2 Tie Rod
10 036J6040 2 Return Spring
11 036J6041 2 Clevis Pin - Tie-Rod to Lever
12 036J6042 2 Clip
13 036J6043 2 Adjuster Nut, Handbrake
14 036J6044 2 Operating Lever, Handbrake
15 036J6045 2 Pin - Operating Lever to Clamping Lever
16 036J6046 2 Cotter Pin
17 036J6047 4 Centralising Strip
18 036J6048 2 Bolt, Centralising Strip Mounting
19 036J6049 2 Washer, Centralising Strip Mounting
20 036J6050 2 Nut, Centralising Strip Mounting
21 050J6022 1 Pad Set - Rear
22 036J6063 1 Pad Set - Handbrake
23 026J6002 4 Bolt - Caliper Mounting
