This is a near new Jaeger (Smiths) Dual Oil/Water Gauge Degrees in Fahrenheit
Model GD1501/01
Purchased from Rimmer Bros. Part No.: BHA4296
(IMPORTANT NOTE: This is interchangeable for the same gauge with the “Smiths” name/logo on the dial, being no difference between the Jaeger logo’d gauge and the Smiths logo’d gauge. My Elan arrived from the factory in 1965 with the Jaeger logo’d gauge, which was an exact visual and operational match to the tach and speedometer fitted in the car except for the name/logo only. The Smiths model for which this is interchangeable is Model GD1501/14 or GD1501/14A Rimmer Bros. Part No. BHA4586)
It was purchased new, and used in my '65 S2 Elan for only 1000 miles while waiting for my original rebuilt gauge to arrive. Works perfectly and looks as new.
Comes with a used but perfectly good mounting bracket.
The length of the water temp tubing is 84" or 5.6 feet.
The water temperature sensor is bulb type is A2
The obvious question is "Why not buy a new “Smith’s” dual gauge of this model?
Simple, the official manufacturer of all new Smith’s and Jaeger gauges, Caerbont Automotive, has been consistently using a worn out printing plate when manufacturing this model of gauge with the “Smiths” logo on the face- and the quality and look of these new gauges is sub-par resulting in blurry face lettering that does not match the sharp and clean printing on the faces of original instruments made in the 60’s. See the photo below.
I purchased a new Smith’s gauge and then returned it because it looked so bad and did not match the quality of printing of my other instruments. I found that everyone selling the new Smith’s dual gauge indeed was stuck with inventory that had the blurred printing.
The difference between the Jaeger and Smith’s gauges are readily and obviously apparent especially when mounted in the dashboard and seen next to each other, and the new Smith’s gauge really looked out of place, even more so than is shown in the comparison photo below.
I then discovered that the same exact new gauge with the “Jaeger” logo instead had retained the sharp clean printing found on the original gauges- and so ordered that one to use while I awaited for my original gauge to arrive from being rebuilt, which I have now swapped out, making my new Jaeger gauge available to anyone who needs a replacement for either the Jaeger or Smith’s logo’d gauge.
The price of the new Smith’s gauge (with inferior printing) from Rimmer is $225 incl. shipping to the USA, the Jaeger version (with sharp clear printing) being $266 incl. shipping to the USA.
My price is $160 plus cost only for whatever shipping you choose. The small rubber gasket sometimes found between the back of the bezel and the dashboard is not included.
Important: Make sure this is the exact type for use in your car and that the A2 bulb type is used in your engine block. CAREFULLY and CONSCIENTIOUSLY shipped and protected with insurance. Respectfully, no returns with the exception that it is tragically damaged in shipment.
Thanks, Neil Slade ![]()
1965 S2 Elan
FYI, I am a 100% ebay rated seller/buyer
you may reply to [email protected]
CLICK TO ENLARGE COMPARISON PHOTO
