How high do I need to lift the body?
Sorry to be ambiguous.
I have removed my bodyshell and I measured from the floor to the highest point of the rear shock tower with the wheels on. If you are critical for headroom you could remove the wheels, put skids under the hubs and pull the frame out. If you have the space to pull it out sideway would require even less headroom. The difference is on account of the transverse tunnel over the rear axle in the body tub.
Just been out and looked at my frame and the body. To do a sideways move you might be able to get away with little over a foot - to do it fore & aft about two feet. (34.5" minus 6" +/- ground clearance of the body). The front end doesn’t look so critical.
Let me know if you need more dimensions.
Jon.
