Engine block identity
I have what appears to be a replacement engine block.
Casting marks only. Hopefully no legal issues.
Photo shows boss lacking serial number. Hope the image works:
This vertical area is not where the unique lotus elan twincam ID number would be stamped (the photo rather displaying a grounded off cast number): the stamped engine ID is located on a machined horizontal flat on the intake side above the engine mount (the one with a cast L if applicable)
lotus TC block ID
Yes thanks, I can see a couple of numbers now but most are unreadable.
Tom
you may want to try under grazing light or enhancing the stamping with stain/ink, or to make a paper imprint by rubbing wood… knowing the sizeand font of the letters/numbers may help, too… good luck!
Good thought, will do.
Tom
