has anyone any ideas where i could get some,and if fitted to any other cars or makes/models???.
The set that I bought a years or so ago came fro R.D. Enterprise.
Lee Levey
64 S-1
r.d. enterprise?,where are they?
…right here http://www.rdent.com Ray is in Quakertown Pennsylvania, good guy, my phone records are old but the number I have is 215 538 9323 Good Luck
The early S1 items were made of sheet steel and would be easy to fabricate , the next version were a bit more refined. If your car is early eenough to have the sheet steel ones I would go that route.
its early enough to be sheet steel ones but i need a pattern or dimensions,can you help?.
I took some photos and they will follow shortly to your e-mail
Rectangle in shape,
1.5 X 1 inch ( short dimension top to bottom)
Has small lip over top of window glass
Radiused lip facing passenger compartment ( 5/8" at center)
Chrome plated
Fastener dwith panhead sem and threaded sellock like washer
Do you have window lifters for the S2 also?
Bill
