Help! Sorry, this is going to be long winded, but I think I need to explain properly. In my type 26 Elan I have a recently rebuilt Sprint big valve spec engine, which has been running on the car’s original DCOE 18 carbs. With the Webers the cars has never run sweetly on light throttle openings, not the dreaded off idle stumble, just uneven running. Having tried everything I could think of, I bought a pair or reproduction Dellorto DHLAs (made by FAJS) off Eurocarb who jetted them correctly to Lotus Twin Cam spec for me. I’ve had DHLAs on a fairly highly tuned Ford Crossflow plus my 1974 Alfa and I’ve found them to be more accurately tuneable than the DCOE18s and give better running on part throttle. These FAJS reproductions seem quite well made and use standard Dellorto components. They are repros of the pre-emission 3 progression hole DHLAs.
I’ve now fitted the DHLAs but I’ve hit a problem which I have been unable to solve. At idle number 2 cylinder does not fire at all. I’ve put a Colortune Plug in it and, although one can see a healthy spark, there is no burn at all. Open the throttle a bit and you get a very erratic yellow burn. At higher revs there is sporadic missing and plenty of pops and bangs.
I’ve balanced the carbs with a 4 way manometer (and checked it with a Synchronometer). No 1 & 2 cylinders required no air bleed to balance them, 3 and 4 did a little.
I’ve checked lots of things to no avail, No 2 still not firing at all at idle:
Changed spark plug
Clear strong spark on the Colourtune
Oscilloscope on No 2 spark plug lead at idle shows strong initial spark and longer burn period than the firing cylinders.
I’ve swopped jets and their holders between cylinders 1 and 2 and also the idle mixture screws likewise .
I’ve compression tested no 2 cylinder, over 200 psi.
I’ve verified that the channel between the progression hole inspection well and the mixture screw well is clear and also the hole from the mixture screw well into the inlet tract.
After the engine has run, there is evidence of petrol in the progression hole inspection well, just as there is on No 1 cylinder.
At the best idle I can achieve, the butterflies are just over half way across the first progression hole.
I’ve checked float levels.
Another strange thing is that at the best idle I can get (on the 3 cylinders that work) with a nice blue flame on Colourtune is with the mixture screws out 6 or 7 turns, which is beyond the range given by Des Hammill in his book, suggesting that the current original Lotus spec 50 idle jets are too small, but when I swopped them for some 58s I happened to have, it still required 6 or 7 turns to achieve a decent idle!
Any thoughts anybody I’ve just run out of ideas?
Yours in hope and anticipation.
Vernon
