Dellorto DHLA 40 vs DHLA 40E
Hi Everyone
A question
As some people here may realise, I own a '73 Elan 130S/5 and a '74 Europa Special. Now, both these cars have identical the engines with the exception of the carburettors which are Dellorto DHLA40 on the Plus 2 and DHLA40E on the Europa. As far as I’m aware the difference between these carburettors is that the DHLA40 has 4 progression holes while the 40E has 5 so, what I would like to know is, how would this difference affect how the engine performs and also can anyone suggest why Lotus would find it necessary to make this change (I am assuming this was an age related change rather than anything related to the different car models). Thanks very much
Andy
I found (in several places) this text online, attributed originally to the “sideways technology” forum, but I didn’t find the orignal message.
Also, according to this post:
viewtopic.php?t=1887
the DHLA40E was also fitted to some later Sprints and Plus 2s.
Hope this helps.
Paddy
Also, the E version has idle bypass screws, which enable precision balancing of the carb throats. On a normal (non suffix) version, you can only balance from carb to carb. On the E version, the bypass screws let you achieve optimum balance within the individual carb.
It’s a nice feature, and is one of the reasons I obtained a set of E’s for mine.
Hi Guys
Thanks very much for that
Andy
