| Item | Lotus # | All | +2 | +2 FED | +2S | +2S FED | +2S 130 | RHD | LHD | Description | Change Point Notes Bulletin Reference |
| 1 | 050B0697 | 4 | Casting - Door Hinge | ||||||||
| 2 | 036C6002 | 4 | Bush - Hinge | ||||||||
| 3 | 050B1002 | AR | Shim - .030 ins., Hinge Adjustment, Optional | ||||||||
| 050B1002A | AR | Shim - .028 ins., Hinge Adjustment, Optional | |||||||||
| 026B0079 | 8 | Washer, Hinge to Body | |||||||||
| LUFN050F | 8 | Nut, Hinge to Body | |||||||||
| 4 | 050B0860 | 2 | Hinge Rod Assembly | ||||||||
| 5 | 050B1000 | 2 | Spacer, Hinge Rod to Door, Bottom | ||||||||
| 6 | 050B6006 | 2 | Washer, Hinge Rod to Door, Bottom | ||||||||
| 7 | A050B2026 (W064) |
2 | Screw, Hinge Rod to Door, Bottom | ||||||||
| 8 | 050B0903 | 2 | Nut Plate, Hinge Rod to Door | Top | |||||||
| 9 | L04W0000 | 4 | Washer, Hinge Rod to Door | Top | |||||||
| 10 | XUFS0412 | 4 | Screw, Hinge Rod to Door | Top | |||||||
| 050B6007 | 1 | Door Check Assembly LH | |||||||||
| 11 | 050B6008 | 1 | Door Check Assembly RH | ||||||||
| 12 | MUCS0412 | 1 | Bolt - Check to Door | ||||||||
| 13 | XUCB0408 | 2 | Bolt - Check to Body | ||||||||
| 14 | A050B1942 | 2 | Bush - Check to Body | ||||||||
| L04W0000 | 2 | Washer - Check to Body | |||||||||
| 050B6019 | 1 | Door Lock LH | Upto Chassis No. 0928 | ||||||||
| 15 | 050B6020 | 1 | Door Lock RH | Upto Chassis No. 0928 | |||||||
| 036B6048 | 1 | Door Lock LH | From Chassis No. 0929 | ||||||||
| 16 | 036B6049 | 1 | Door Lock RH | From Chassis No. 0929 | |||||||
| KUFS0416 | 8 | Screw, Lock to Door | From Chassis No. 0929 | ||||||||
| A04W0906 | 8 | Washer, Lock to Door | From Chassis No. 0929 | ||||||||
| YUFN040F | 8 | Nut, Lock to Door | From Chassis No. 0929 | ||||||||
| 050B1005 | 1 | Cover Plate, LH | Upto Chassis No. 0928 | ||||||||
| 17 | 050B1006 | 1 | Cover Plate, RH | Upto Chassis No. 0928 | |||||||
| KUFS0416 | 6 | Screw - Cover Plate to Lock | Upto Chassis No. 0928 | ||||||||
| 050B6021 | 1 | Striker Plate LH | Upto Chassis No. 0928 | ||||||||
| 18 | 050B6022 | 1 | Striker Plate RH | Upto Chassis No. 0928 | |||||||
| 19 | 050B1278 | 2 | Tapping Plate | Upto Chassis No. 0928 | |||||||
| 20 | 050B1214 | AR | Shim | Upto Chassis No. 0928 | |||||||
| KUFS0424 | 6 | Screw - Striker Plate to Body | Upto Chassis No. 0928 | ||||||||
| 21 | 036B6054 | 2 | Striker Plate | From Chassis No. 0929 | |||||||
| KUFS0424 | 4 | Screw - Striker Plate to Body | From Chassis No. 0929 | ||||||||
| 22 | 036B6055 | 2 | Cover Plate - Striker | From Chassis No. 0929 | |||||||
| 23 | 050B6023 | 2 | Clevis Pin, Remote Control Link to Lock | Upto Chassis No. 0928 | |||||||
| 036J6031 | 1 | Split Pin, Remote Control Link to Lock | Upto Chassis No. 0928 | ||||||||
| 24 | 050B6024 | 2 | Washer, Remote Control Link to Lock | Upto Chassis No. 0928 | |||||||
| 050B0683 | 1 | Link, LH, Remote Control to Lock | Upto Chassis No. 0928 | ||||||||
| 25 | 050B0684 | 1 | Link, RH, Remote Control to Lock | Upto Chassis No. 0928 | |||||||
| 26 | 050B6025 | 2 | Remote Control Mechanism | Upto Chassis No. 0928 | |||||||
| 27 | XUFS1010 | 4 | Screw, Remote Control Mechanism to Door | Upto Chassis No. 0928 | |||||||
| 28 | LUFN100F | 4 | Nut, Remote Control Mechanism to Door | Upto Chassis No. 0928 | |||||||
| 29 | A03W0605 | 4 | Washer, Remote Control Mechanism to Door | Upto Chassis No. 0928 | |||||||
| 30 | 050B6028 | 2 | Handle - Interior | Upto Chassis No. 0928 | |||||||
| 31 | PUFS1008 | 2 | Screw - INterior Handle Mounting | Upto Chassis No. 0928 | |||||||
| 050B0815 | 1 | Exterior Door Handle LH | Upto Chassis No. 0928 | ||||||||
| 32 | 050B0816 | 1 | Exterior Door Handle RH | Upto Chassis No. 0928 | |||||||
| 33 | 036B6132 | 2 | Gasket - Exterior Door Handle, Front | Upto Chassis No. 0928 | |||||||
| 34 | 036B6133 | 2 | Gasket - Exterior Door Handle, Rear | Upto Chassis No. 0928 | |||||||
| XUFS1008 | 4 | Screw, Exterior Handle to Door | Upto Chassis No. 0928 | ||||||||
| L03W0000 | 4 | Washer, Exterior Handle to Door | Upto Chassis No. 0928 | ||||||||
| A03W0605 | 4 | Washer, Exterior Handle to Door | Upto Chassis No. 0928 | ||||||||
| 050B0507 | 1 | Trigger - Exterior Door Handle LH | Upto Chassis No. 0928 | ||||||||
| 050B0508 | 1 | Trigger - Exterior Door Handle RH | Upto Chassis No. 0928 | ||||||||
| 036J6031 | 2 | Split Pin - Trigger to Handle | Upto Chassis No. 0928 | ||||||||
| 036B6052 | 1 | Exterior Door Handle LH | From Chassis No. 0929 | ||||||||
| 35 | 036B6053 | 1 | Exterior Door Handle RH | From Chassis No. 0929 | |||||||
| 36 | 036B6164 | 2 | Gasket - Exterior Door Handle | From Chassis No. 0929 | |||||||
| 036B6149 | - | Gasket (replaced by 036B6168) | From Chassis No. 0929 | ||||||||
| 37 | 036B6168 | 2 | Gasket - Exterior Door Handle | From Chassis No. 0929 | |||||||
| XUFS0310 | 4 | Screw, Exterior Door Handle to Door | From Chassis No. 0929 | ||||||||
| A03W0806 | 4 | Washer, Exterior Door Handle to Door | ,From Chassis No. 0929 | ||||||||
| 036B6050 | - | Remote Control Assembly (replaced by 036B6151) | From Chassis No. 0929 | ||||||||
| 036B6151 | 1 | Remote Control Assembly LH | From Chassis No. 0929 | ||||||||
| 036B6051 | - | Remote Control Assembly (replaced by 036B6152) | From Chassis No. 0929 | ||||||||
| 39 | 036B6152 | 1 | Remote Control Assembly RH | From Chassis No. 0929 | |||||||
| 40 | 036B6256 | 2 | Handle - Remote Control | From Chassis No. 0929 | |||||||
| 41 | 036B6257 | 2 | Pivot Pin - Remote Control | From Chassis No. 0929 | |||||||
| PSTS1006 | 6 | Screw, Remote Control to Door | From Chassis No. 0929 | ||||||||
| 050B6009 | 6 | Nut, Remote Control to Door | From Chassis No. 0929 | ||||||||
| 050B1411 | 1 | Wire - Remote Control Locking LH | From Chassis No. 0929 | ||||||||
| 42 | 050B1412 | 1 | Wire - Remote Control Locking RH | From Chassis No. 0929 | |||||||
| 050B1423 | 1 | Wire - Remote Control Operating LH | From Chassis No. 0929 | ||||||||
| 43 | 050B1424 | 1 | Wire - Remote Control Operating RH | From Chassis No. 0929 | |||||||
| 050B1413 | 1 | Wire - Door Handle to Lock LH | From Chassis No. 0929 | ||||||||
| 44 | 050B1414 | 1 | Wire - Door Handle to Lock RH | From Chassis No. 0929 | |||||||
| 036B1647 | 1 | Wire - Private Lock to Lock LH | From Chassis No. 0929 | ||||||||
| 45 | 036B1648 | 1 | Wire - Private Lock to Lock RH | From Chassis No. 0929 | |||||||
| 47 | A036B6191 | 2 | Private Lock | From Chassis No. 0929 | |||||||
| 036B6096 | 2 | Gasket - Private Lock | From Chassis No. 0929 | ||||||||
| 226 | 2 | Locknut, Private Lock Mounting | From Chassis No. 0929 | ||||||||
| A036B1925 (W015) |
2 | Friction Washer, Private Lock Mounting | From Chassis No. 0929 | ||||||||
| 036B1410 | 2 | Washer, Private Lock Mounting | From Chassis No. 0929 | ||||||||
| 48 | 036B6146 | 12 | Fastener Assembly | ||||||||
| A036B6251 | 12 | Fastener, Wire Fixing | From Chassis No. 0929 | ||||||||
| 036B6056 | 12 | Bush, Wire Fixing | From Chassis No. 0929 | ||||||||
| 050B6122 | - | Rod Clip - Guide (replaced by A050B6148) | |||||||||
| 50 | 050B6148 | 6 | Rod Clip - Guide | From Chassis No. 0929 | |||||||
| 050B6123 | - | Plastic Tube (replaced by A050B6164) | |||||||||
| A050B6164 | AR | Plastic Tube - Wire Sound Insulator | From Chassis No. 0929 | ||||||||
| 51 | 050B1520 | 1 | Steady Bracket RH, Rod Clip Mounting | From Chassis No. 0929 | |||||||
| 050B1521 | 1 | Steady Bracket LH, Rod Clip Mounting | From Chassis No. 0929 | ||||||||
| PSTS1008 | 2 | Screw, Steady Bracket to Door | From Chassis No. 0929 | ||||||||
| 424 | 2 | Nut, Steady Bracket to Door | From Chassis No. 0929 |
