I have just converted the dynamo on my car over to an Elan and fitted the alternator, amnended the wiring as per the instructions located within the forum and manual.
The problem is that prior to the changeover the IGN warning light will not light up on switch on, and worked before I removed the control box.
The following are connections I have at the alternator :
I have 1 small connector (brown/green) connects to Bronw yellow
I have 1 large FAT CONNECTOR - TO SOLENOID
1 have another FAT CONNECTOR - BROWN /BLUE (2 CABLES)
I spare small terminal at right angles to the above.
Is there anything I have missed - and keep checking wiring and stoll can’t get it to light up.
Tips and assistance welcome and appreciated.
