+2 rear brake rebuild
Just finished rebuilding the front brakes on my 1970 +2. Removed rear brakes for rebuild, trying to remove parking brake assembly from the caliper. How do you remove the pivot pin, it appears to have a threaded hole in the center of each pivot pin. The manual has no guidance, any ideas?
viewtopic.php?f=42&t=26591
The above topic explains the pin removal.
This might be worth a look
youtu.be/s5nrMtcBBS0?si=X-5Chlqr3KbojqY2
