Might anyone have their 130 +2 crashpad off? Would you please take a photo of the ends of the lower panel and how it connects to two brackets that in turn are held in place by the door light switch?
I have everything off without taking much note of how it came off and cannot make head nor tail of it
I have searched t’internet for an exploded view, but so far no luck. If anyone has a link to such a thing, will you send it to me please?
I fitted a new dashboard many years ago. I still have the old one. The brackets are attached to the dashboard underneath the ventilation “eyes” with two small woodscrews 3" apart., see pic. It looks like the height was changed at some stage.The drilling looks like maybe a small bolt was also added, as the screws are very flimsy, I can’t remember.
Thanks Foxie - I will see if this makes sense with what I have. Lining them up as I thought they should be, the brackets are in the centre of the vents! But maybe if I reverse them, they will line up as you suggest… Tomorrow. I shall sit in the sun this afternoon!
Another one - do you know if the bottom of the dash board is meant to sit on the tunnel ahead of the gear lever, or is it held off by the two bolts? (I am making a complete new one for the lhd conversion, but the existing board is a bit of a mess down there and hard to tell…)
I think ideally it should sit snugly on the tunnel, with the bolts just restraining it in the forward/rear axis. You might need to slot the bolt holes in the angle bracket to avoid unnecessary stresses on the timber dash.
I can confirm that the dash does not sit on the tunnel but is held off the tunnel by approx 3-4mm. At least mine is.
How I know this is because when fiddling around a couple of months ago making a gearlever grommet surround plate for my Type 9 gearlever the original gearlever grommet surround just slides under the dash between the dash and the tunnel.
It looks like mine might not have rested on the tunnel, but difficult to say for sure as the bolt holes are a mess and both collars are missing.
As it is a dash that I am making, I can size it to be anything. I agree with Foxie that resting on the tunnel reduces any stress, but are there any downsides I ask?
I’ve just checked my old dash. The bottom section is 11.5" wide, but there is a 4.5" x 1/4" recess in the bottom centre, and the new one, which I took photos of when fitting, is exactly the same. So only the outer sections sit directly on the tunnel.
BTW, I also have a T9 gearbox, and the gear lever cover plate also neatly slots in under the dash !
Bracket is bolted to a stud plate (050b1208… see parts book in wiki) which is attached to the back of the dash with 4 screws as shown at bottom left of the picture below.
Just to add to the responses so far.
As noted by Brian, there is a mounting plate fitted to both ends of the dash. If you need to make these, they are 4 1/2" long x 3/4" wide and have two 3/16" diameter captive studs (10-32 UNF) at 3 1/2" centres. Fixings to dash are with four No4 x 3/8" long countersunk wood screws.
Couple more pictures to illustrate.
Hal,
See attached pic which will perhaps help you understand why it would not be desirable to have the Dash sitting hard on the tunnel. It will cause you issues with sorting the gearlever grommet.
As you can see the aperture for the gearlever grommet, goes forwards under the dash cutout so a gap is necessary.
Gary - a big thanks! I scoured the place this morning with no luck. In the back of my mind I remember seeing these and must have put them somewhere. They will turn up in ten years time maybe!
I see the four holes in my old dash, so with your measurements and where they are placed, easy to continue, if not laborious.
Alan yes, as I mentioned above, I too will have a T9, so useful to have the cutout, and have the dash rest on two legs so to speak. So thanks too!
I am making a lhd conversion that will incorporate an XR3i steering column a la Evante. I need to make a template to get the correct shape around the steering cowl for which I shall cut up and use the original facia. On lining it up, I see that the whole facia is held in place at four points - two on the tunnel and two under the air vents, yes? I cannot remember if there were any others.
The four bolts along the top underneath the crashpad nose hold the plate to which the screen vents are bolted, with the crashpad sandwiched between this plate and the facia. Are there any mounting points of this plate that I might have forgotten, or is the whole lot cantilevered off the four bolts on the top of the facia?
