The factory manual and Buckland’s book both do not show this tandem brake master cylinder. I’ve searched the forums without luck to identify it. Can anyone show me what the OEM master brake cylinder looks like for this car? Does the OEM version have a cork as the float for the cap connection? This car does not have vacuum assist and is left hand drive (USA).
This could have also come from an Elan Sprint as parts of this car came from a Sprint.
Glenn, it looks exactly like that, as I said in your other thread you have the SOVY system fitted to a federal tandem system’ it’s all original!! Ray has a rebuild kit if you need it.
Mazzini, yes I have the brake fail warning light on the dash.
Phil, I looked everywhere for info in the prior posts on this site on the sovy tandem cylinder and only found one post which didn’t give me a lot of information. I’m suspect of any brake master cylinder theses days as I’ve seen a number of variations and my own Elan S1 came with a tandem master that was not OEM. I’m just trying to figure out if this is original to the car and if so, is the float really made of cork?
Phil, no wonder I couldn’t find the post for the Sovy, I didn’t look up liquor store. Now what was I thinking
I just located a new sovy OEM cap from a reliable source along with some other impossible to find parts that I have been looking for around the world. One step closer to completing my S4 with factory original parts.
My master cylinder looks like yours, except that the Sovy unit is in storage now. The plastic part between the master cyl and the metal container cracked, so I just have a plastic cap on the reservoir like Jon the Chief’s picture shows. I have the dash warning light also.
Bob, thanks for the confirmation! I wanted to be confident that the SAVOY part was original so when I replaced it at a rediculous price I wouldn’t be too upset. I think this is the last hard to find part I need to finish restoring my S4 with Sprint enhancements.
There is always a surprise when it comes to Elans… either that or I just don’t know these cars well enough.
So I get my new old stock master brake cylinder cap with cork float (probably the last one on the planet) from a great source in the US and I go about installing it today on the metal extension above the plastic reservoir for the brake fluid. I fill the reservoir enough for the cork float to make contact with the electrical connection in the cap and all of a sudden I see brake fluid seeping out of the lower part of the metal canister. What the heck?
Disassemble and look closely to find out compared to the photos on this post I have replica metal canister that does not seal to the plastic reservoir. It doesn’t screw down far enough to seal.
So now I am looking for the metal canister. Does anyone have one for sale?
Glen, there should be a plastic cap to the master cylinder reservoir, it is drilled & a brass fitting clamps the cap to the metal sovy can with a seal between the two. All of the parts are shown here:
It’s not a particularly robust design, if either the seal in the plastic cap, or the seal between that cap & the bottom of the reservoir are not perfect the assembly will leak.
I am unclear from your picture if these is a plastic cap on your reservoir? Or if the metal can screws directly onto the reservoir?
