I have finally gotten my TC running. Cleaning/servicing of the distributor advance mechanism and proper adjustment of the idle mixture screws has done the trick.
I remain concerned over the safety of the fuel delivery for the Zenith Stromberg carbs. I am running a brass “T” with two short lengths of flex fuel line to the “T”, which is positioned between the carbs, with the 1/4" fuel line from the pump attaching to the third “T” leg.
It appears that the “T” , supplied by the engine re-builder, has leg diameters for 1/4" fuel line. Part of the problem is that the carb feed lines are of a smaller diameter. The hose stretches a bit to fit onto the 1/4" “T” legs. Source for a “T” with two smaller (3/16"?) and one 1/4" legs?
Furthermore, the hose to “T” system , I feel, is not ideal. Has anyone changed this? I understand that same Z / S carbs have different (safer?) fuel delivery attachments on other applications such as the last year of the Triumph Stag and the Rolls Royce. Anyone familiar with these?
Bob
1969 Elan +2
