The crossflow engine I am currently having rebuilt requires that the pistons be heated to allow the wrist pins to be moved as they are an interference fit.
Unfortunately the initial engine builder / machine shop noticed the tight fit and honed the piston to allow the wrist pins to easily be pushed in by hand.
I am confident that they were designed that way to provide the correct fit once the piston and engine are at operating temperature. The book on crossflow engines clearly shows the pistons being heated in order to move the wrist pins. The engine builder was given that book by me to familiarize him with dimensions and this procedure.
I am now confronted with a dilemma. Do I get a new set of pistons hoping they match the bores already matched to this first set or do I leave them this way and risk piston and bore wear with no .030 over pistons available for the pre-uprated engine. The pistons fit now are .020 over.
I will call this first engine builder to demand a substantial refund to pay for the remediation of the cam bearing and now this.
How I hate “Experts” This is why I do every thing I possibly can myself
However to get back to your question, Pin on a twin cam should not be an interference fit although they shouldn’t be loose either. Sometime the pins can get a little stuck if they’re new and have been coated with oil which has dryed. In these cases a little heat might help but only something like some hot water.
In general I would say if its a warm day the pins should push through the pistons with your fingers with just a little resistance. Once in place they they should not fall out under their own weight though, if they do they’re too loose.
I would guess, unless the guy who you gave the job to was totally incompetant, you’ll most likley be ok, the point is however you should’nt really have been put in the position where you have to ask questions like this. Pins are ground to a tolerances of one or two tenths, why anyone should consider it necessary to “open them up a bit” I cant imagin.
That is what happens with some “experts” who learned by doing not by thinking. “I’ve rebuild 500 such and such and thats the way it is done”. I would ask that since the rebuild book indicates that the pistons on the crossflow be heated to allow pin removal, why would you defeat that?
Many engine builders have distain for engineers thinking them “egg heads” as their “real world” experience allows them to know better. It never seems to sink in that designs vary and if a job is done one way on a certain engine does not mean it is done the same way on others.
I would also add that there had to be a reason a tight interference fit was specified on the crossflow. It certainly was not added as a superfluous feature to confuse know it all technicians. I assume the material used to make the piston will expand enough as to need these tight tolerances.
I am hoping that another new set of pistons will be so close in diameter as to fit in my bores as presently dimensioned. I will then ask for a substantial refund to cover my expenses to rectify his error even though he will respond "they are all supposed to be like that!:.
I am tired of paying and then paying again to get it done right. I will sue the idiot if need be. I will not go gently into that dark night!
The Elan and Elan +2 work shop manuals both say “heat the piston in water to allow the gudgeon pin to be fitted”. I have always let the pistons sit in boiling water for about ten minutes and after that the gudgeon pins slip in easily, pressing with a finger. The gudgeon pins are a light interference in the piston when both parts are at the same temperature. I have answered your question about TC pin fit however you are rebuilding a crossflow. I don’t know what the pin fit should be for the crossflow. If it was a TC the mechanic who honed the pin bores would owe you a new set of pistons and pins.
My original engine had Cosworth forged pistons. The gudgeon pins (wrist pins) were a tight fit so the pistons needed warming. My latest engine has QED pistons which are a light push fit cold. To quote Miles Wilkins (from his book ‘Lotus Twincam Engine’) “The pins are a sliding fit but if they are slightly tight, warm the pistons by using a fan or radiant heater or by placing them in hot water…”
In any case, surely the pins won’t fall out as long as you fit the circlips?
My primary concern is that the interference fit is designed so as to allow the alloy piston to expand when at operating temperature and not have excessive “play”. If it does develop a sloppy pin to piston fit I am concerned that the piston may knock or rock within the bore. I have no concern that the pin will dislocate.
I don’t really know that much about X-Flows but do the pistons actually have any circlips. I had a feeling that the piston pin was an interference fit in the connecting rod and the piston then pivoted about the pin. If this is the case then chances are you should be ok provided that clearance isn’t excessive, it isn’t an issue with the Twin cam after all. Don’t forget, because the parts are moving relative to each other, there has to be a little clearance to get an oil film between.
I’m with you however in that I do wish people wouldn’t always seem think they know better than the original designers. I do believe Ford probably knew a little bit about engines after all.
I’ve worked on lots of Xflows and they have a fully floating gudgeon pin with circlips and for all intents and purposes the pin fitment is the same as Twin Cams, I have had Xflow pins that both went in with a finger push and some need a bit of heat (boiling water poured over them works well) also depending on ambient temperature but as long as the pins are not a sloppy fit I doubt weather there will be a problem, although I would not have too much faith in an engine builder who felt it necessary to alter the pin to piston fit when they are supplied ready to fit with the correct tolerance.
I agree. I have no faith in the initial engine builder which is why the engine is at another shop now.
The pin to piston clearance is between .0001 to .0002 inch.
The cam bearing problem was satisfactorily resolved with the installation of a new set of cam bearings. It is possible the initial engine shop improperly fit the #1 cam bearing. Not a surprise.
My JE forged pistons came with an easy push fit out of the box. The racecar machine shop honed the pistons to increase the clearance slightly because “we do that for all JE pistons.” I was worried for a while, but after 3000 miles of hard driving with a 7500 rpm redline still no problems.
Used JE pistons for years in my engines - I think they know more about setting up the clearances between their pistons and gudgeon pins than me or any other “race machine shop”. “Honing ths clearance” may not have done much damage if they did not alter it signficantly but I doubt it did any good either and I bet they charged you for it.
I would also bet they had no specific dimension or tolerances on the new fit they created that they specified for you and I doubt they had any engineering basis for what they were doing.
If JE had it wrong I think they would have changed what they supply by now. I have always used the as supplied fit and never had any problems and JE keep there tolerance very tight so the fit is always the same on every piston I have got from them
PS In the business I manage I spend a lot of time with the maintenance and engineering departments to ensure that when they make a change like this it is properly documented and has a sound engineering basis and that the outcomes are rigorously tracked in the future. Uncontrolled changes whether it be by DPO or race engine shops is a recipe for future problems.
Unfortunately at this point I have little choice but to use them as “modified”. The first engine builder did this and I am most upset because he was only to fit the pistons to the engine bore. Not the wrist pin to piston.
To fit new pistons would be difficult as they are .020 over and that is all that is available. At best I would have to ask the vendor to “select” pistons of certain diameters and make up a set.
Another DPO find. One con rod is 15 grams lighter than the others. The adjustment “pad” was completely ground off and the sides of the rod thinned. “New” used one on the way.
Well, the machine shop I use is a real racecar machine shop not one in quotes. You can go to their website for a partial list of pro customers, but the short story is they have been winning for almost 40 years, so I trust them. accellodyne.com/
They dimension all of the JE wrist pins the same and I can find out the number they use if it is important.
Just remember though, racers often run wide clearances because a free engine will produce more BHP. The fact that it might be noisy and have limited life before it needs a rebuild won’t be a problem for them as BHP means everything. For a road engine things are different. Here smooth quiet running and long life usually take priority over ultimate power. Also, in general, a road engine can usually be given a longer and gentler running-in period after a rebuild than can a race engine.
I suspect this sort of thing could be a problem if you give an engine intended for road use to even a reputable race shop unless you explain exactly what it is you want from them.
The only area a race engine may need wider tolerances is piston to bore clearances and exhaust valve clearance. These may be required due to hotter exhaust valves and piston tmepratures in a race engine.
In all other areas such as bearing clearances while you may select a specific point in the normal tolerance band and that may be at the high end of the spec range you typically dont increase the clearances.
For gudgeon pins to pistons the clearances become bigger at the higher operating temperatures in a race engine than in a road engine as has been observed in othr posts and I dont see the need to increase this clearance from the manufacturers spec if your confident in the manufacturers tolerancing and check that it is OK when you recieve them. Some people like fully floating gudgeon pins that float in both the small end bearing and in the piston. The JE fit is effectively fully floating as the light finger push fit into the pistons at room temperature will dissappear at operating temperature. I dont beleive you should or need to hone the pistons to make it freely floating at room temperature. The only reason to hone it if the fit was to tight in the first place due to incorrect manufacture and maybe some engine shops have got into a hait of honing all pistons to ensure they get a fully floatig end result.
It appears to me that automatically honing a piston wrist pin bore is most likely a habit based on some engine or after market piston that may have needed that done and it carried over to doing it with every engine many shops rebuild.
I am still conflicted as to what I should do. Use my pistons with the honed pin bore or attempt to get a new set of pistons which will match my present bore diameters.
Just to clarify my position, I no more agree with modifying parts anymore than does Rohan. I may check items, but I’ve never found it necessary to alter anything. I was simply stating the things I’ve heard said by others who beliveve it necessary. Personally I think they’re wrong.
None of this helps you of course who now has a set of pistons which, right or wrong, have been messed about with. Certainly complaine to the guy who did the work but in the end I think you’ll end up using the piston as they are. I can’t really see there will be a problem, especially if the 1 to 2 tenth (1 tenth = 0.0001 inch) clearance is correct. I really wouldn’t have thought it nesessacy to go as far as buying new pistons. Whats happened might not be ideal but I’m sure you’ll be ok.
If I were to contact the shop who did the honing of the wrist pin bore they would become indignant and bore me with details of their 30 years experience. It would not just be justifying their actions but they honestly believe it the correct thing to do. If pressed on why I am certain their answer would be suspect.
I always try to get the best possible information so when a job is done it doesn’t have to repeated at a later date.
Thanks to all ho responded. Once the car is running I will listen for any wrist pin knock.
