I have a 1968 Elan coupe. The wipers are hopeless — slow and skipping. They are unsafe in the rain. I feel that they are going to fail soon.
Has anybody replaced an Elan’s wiper mechanism completely — wiper motor, drive mechanism, wheelboxes — with a new modern system? I’m sure that there are motorsport wiper systems available if I only knew where to look. Is there a mechanical wizard who has adapted a system from a modern production car and would be willing to share his knowledge?
Not sure about adapting a modern system, but try Car Builder Solutions. The kit shown looks as though it should be more a less a direct replacement for the original
Hi! not sure about wizard,but i’m developing a complete replacement wiper set-up ,based on a modern motor, for the elan and plus2. I’ve successfully made one for e-type and xk150 jaguars,which we sell at work. After experiencing wipers on my plus2 (two speeds,slow and slower!) i thought i’d turn my attention from work to hobby. Will have to keep you posted,i’m rebuilding car completely.
Martin
I agree about the wipers being less than adequate. I haven’t but in a new sytem, but I do believe I have the original system greatly improved by the following modifications.
I started by putting in a new motor, cable, wheelboxes and arms. This was little better than what came out. This is in a Plus Two.
I fitted a Hella “Variwipe control” with a delay of a few seconds up to half a minute. This was a big improvement, as it was in light rain or merely wet road conditions that the wipers would most likely slow and stop.
I brought the power directly to the wiper motor, through relays operated by the control switches. The slow & stop functions go through a double pole relay, high through a single.
I fitted 13" blades instead of the original 16" to ease the load.
It’s still a long way from being as fast or powerful as a modern system, but it is now 100% reliable.
A 2 litre wedge shaped wash tank from a BMW E30 sits over the fuse boxes, and doesn’t run out on the motorways
I don’t know about the +2 as I have a baby elan. However I have fitted a new motor, cable and wheel boxes as the original ones were just about at the end of their useful life. Great improvement with new standard components
Had the same problem with my 69 S4 last year.
Striped ewrything down and cleaned it with petrol to get rid
of 35 year old grease with no lubricants left. I then packed
the mechanism up with fresh coppergrease and replased it back
in the car. The result was incredible - pulls the wiper blades with
2 speeds on a dry screen.
I’ll bet you still have a generator. One of the side benefits I noticed when I upgraded to an alternator was that the speed of both the wipers and windows doubled.
Back in the eighties I replaced my motor with one from a morris marina - same shape different gear wheels - easy to change, then cleaned everything up as posts above. big difference! still lift off the screen at ninety tho’
