Can anyone tell be what the metal strap in this picture is for. Should it have a rubber seal attached to it?
Jon
Jon
It is the rail for the corner rubber door seal.
Remove them and keep them as a patern for the new seal. The ruber seal should be 2 inches longer towards the front of the car if you want it to impeed some of the rain to get in to the car via the front top of the door.
Best
Carlos
Jon,
Is this another difference between cars of differing ages? My car doesn’t seem to have it? Were they only fitted on early cars and if so, what changed so that they were no longer needed?
I’ve not got one either, and no trace of ever having had one ! Water does occassionally get in at the front of the door so maybe I need one - anyone got any pictures of what one looks like when it’s not missing ?
Steve…
It is in the +2 Parts Manual listed as for all cars Secondary seal (number 2 in the drawing).
Jason
I’ll echo this, if someone could post a pic of an intact one so we can see the profile of the missing rubber that would be great.
Jon
Interesting to see the profile of the original door rubber in that picture Jason, the repro ones I’ve seen don’t look like that…
Wow - I always wondered what that was on my car. Mind you, I only have the metal strip left as well!!
Lee
68+2 No. 244
If i remember correctly. I think the seal came from a Land Rover but i don’t know what model. Perhaps this will jog someones memory
Will try and do this for you tomorrow Jon.
Believe it or not I still have mne
Peter
Thanks Peter, no rush though, it’ll be a while before I need them
Are you heading to Mondello next weekend?
You can buy a weather rubber seal in a car parts store and glue it with high quality glue over the metal rail or remove it and simply glue the seal to the body. Remember: you need a longer piece than the original (two inches more towards the front of the car) if you want that thing to keep at least some of the rain out.
I am traveling (in Brazil) until the 14th so I will not be able to take a picture until then.
Best
Carlos A.
My reward for seeing the question in this post and thinking “perhaps I can help” - this piece is one (two) of a very few things left in the rebuild for which I have (had) no idea what they were for. I had a vague memory of a tacky, ineffective piece of weather seal in that spot but had never seen the metal strip.
Thank you very much!
Now to find the material…
Keith
I would also benefit from seeing a pic of the profile and how it is installed. My PO had installed something completely different on the door, and I had assumed it was the stock set-up.
I bought two seals from Susan Miller last November, but I had no idea how they were installed or what they should look like! When I ordered them, she mentioned “the OE secondary seals are obsolete, but I have something similar which would do”. I can post a picture of what she sent once I see the original to compare to; may help some with finding a substitute locally.
Hi Jon,
Went to take a pic for you this morning…
I don’t have these on my car
Peter
Hi, Just spotted the thread. This looks like an identical type of seal to the one used on Series 2 landrover doors!
Kev
