Ventilation Query
Hi there,
I have a little +2S and it doesn’t blow warm air from the interior vents. I get warm air on to the windscreen but not through the main vents. Is this by design (ie: they’re fresh air vents) or is it broken? If it’s broken, how tricky is it to fix the sliders?
G
Hi There
There is a flap at the bottom of the heater box that moves in order to redirect the airflow. I would guess that there is something amiss with either that or the linkage. To have a proper look it is dashboard out, although you might me able to undo the dashboard fixings and see if you can get clearance to get your hands in there.
Good luck
Berni
