Good afternoon, May I ask what experience do members have of converting from vacuum driven headlights to electric lift? I believe Spyder offer a conversion kit. Do people feel it is worthwhile, does it work or offer any advantages.
Are there any observations/ tips on the conversion itself.
I used a left side electric unit from a Mazda Miata/MX5. Mounted the motor with the armature, end with the red knob, pointing up towards the engine compartment. The lever arm on the motor is on a splined shaft, and can be positioned at any point on the motor shaft. The extension of the armature shaft was done with a section of small diameter aluminum tubing. A piece of a 5.5mm hex wrench served as a broach to match the hex on the armature. The same piece of the hex wrench was used on the far end to attach the red knob from the original motor. With an extension to the shaft, the knob is now readily available to raise or lower the lights should there be an electrical failure from the engine bay. Lift the bonnet, turn the knob, get back in the car and go. There is some fussing about in where the operating shaft from the lever arm of the motor to the link that operates the lights, which may need to have the hole in the link moved to match the length of the motors lever lever arm. A simple 5 pin relay connected to the power side of the headlight switch, switches direct battery to the motor when the lights are turned on. Your choice in where you decide to pick up the direct battery feed.
A quick question about the linkage between pods. Their centres of rotation don’t appear to be in the same plane. If that’s correct, how do you connect them so as to be able to use a single motor?
I came to exactly the same conclusion when I was looking to convert the lift mechanism for my s3 and ended up using two lifters (£60 total cost). viewtopic.php?f=31&t=50274&p=364959#p364959
I’ve done the conversion using the Spyder kit without any issues whatsoever. It works very well, you have the ability to vary the speed at which the pods operate, the pods stay down when parked, stay up when you accelerate and if you flash them using the stalk then they open up and shut back down in a single cycle. All good. The instructions provided are adequate but you still need to make sure all the linkages line up properly.
My originally plan was to do exactly what prezoom has described as I had already sourced an MX5 motor and had the vacuum pod linkage bar from my failsafe setup. But the bar needed a bit of surgery and I wanted some control over the motor speed plus I wanted to be able to flash the lights using the column stalk. I’d researched the “flash to pass” conversion that could be done on the MX5 so that I could use the stalk to raise the pods, flash main beam and close the pods back in one movement. The Spyder solution does all this and provide a custom linkage bar so, apart from funding it, it was no brainer. Then I reached state pension age and had a supply of “no-guilt what I spend it on money” so I did it.
The only thing you really need to know is that the Spyder system still requires one of the vacuum pod springs to enable it to work.
Thank you all for the very helpful info. I need to access my vacuum system as I think it’s been disconnected. Then make a decision.
The flash option, sounds a useful addition. Very tempted to go the Spyder route for reliability.
I’m guessing that once both the vacuum pods are removed and the motor added then the weight difference would be insignificant (keeping true to ACBC’s principles).
Whilst I could fabricate my own system, I think it’s a reason trade of between time to buying the Spyder unit.
I fitted the Spyder kit recently, after several bad experiences with M-ways, bad weather, and HGVs
The kit is well made and everything required is supplied, including instructions. I had to contact Spyder to correctly identify and sort out the many bolts, washers etc.
The 3-position rotary switch for ‘off’ ‘sidelights’ and ‘mains’ is neat and fits into the original vacuum pull switch position.
I got my kit from Kelvedon and I think it’s basically the same as the Spyder kit although it did not include the switch that Foxie describes. Such a switch might have made my install easier, as I found that there was NO point in my car’s headlight wiring system that wasn’t interrupted when changing between dipped amd main beams, meaning that changing beams would result in the lights trying for a moment to retract. My solution was to use the switch for the heated rear screen, as my car has the switch but not the wires on the rear glass. Sure it adds a step to activating or de-activating the lights, but it’s not a big deal given how manual and analog the car already is.
I found that the linkage was easy to connect and that the new bar between the pods that comes with the kit makes for perfect even-ness between the two, just as the original did. Getting it set for the right amount of motion and the right stopping-positions at either up or down was much easier than expected too.
One thing I did do however was add a little more thickness to the floor of the nose, as the spot where the motor mounts seemed a little flimsy and likely to flex during operation. The underside of the nose had some penetrating cracks to be repaired too so I just 'glassed those repairs and the added thickness in one session and now it’s all solid.
The kit works really well and I’m quite pleased with it.
I am not familiar with the Spyder electronic control system or its input circuitry but I would expect that one could use a couple of diodes to ‘OR’ the dip and main wires so that the pods raise whichever light is on.
The way the factory system works at least on the early cars, is that the pull switch on the dash provides ground to both relays[and enables the parking lights through a different micro switch]
The stalk chooses which relay gets enabled
To wire a motor[or vacuum switch] to the factory wiring it is required to provide it switched power at all times, then use the ground to enable the motor.
I used one Miata motor, as the federal system originally used one vacuum pod it is pretty easy to use that system.
If I was designing it today I would probably go for something a little more original looking like this 3 position pull switch that the old headlight vacuum pull knob could be fitted to with a bit of fiddling.
Screw terminals.
Fits in a 10mm hole.
Closed length 83mm.
Maximum open length 103mm. (knob side only 48mm max).
Max panel thickness 8mm.
B - Live into Switch.
58 - Sidelights (that stay on with headlights).
57 - Sidelights (that turn off when headlights on).
56 - Headlights.
30 - Live through switch (to feed another switch).
confirms my memory. Both headlight relays have power always. The dash switch provides ground to both relays, enabling them. The stalk gives 12 volts to one or the other of the relays.
Thus to wire a motor with the factory wiring, one need only tap off the ground wire of the relays[they are jumped together] and provide 12 volt power to the motor[switched would be preferable, but it can be battery power]
As a result, when you pull the factory headlamp switch, it will provide ground to the motor, which already has 12 volts and the headlights will rise. The hi low beam is not important with this wiring scheme.
I found the Miata motor is a little fussy with voltage supply because unlike the GM type motors, it rotates 360 degrees and if it is not given proper power it may get confused and go down or up or whatever. IT prefers switched power which assumes the car is running with 14 volts, and if you switch on the ignition without starting the car, and operate the headlights it ‘may’ fail to run, so I ran a fresh battery line to the motor and it is happier. You may need to start the car to get alternator voltage and cycle the switch to get it to do its thing
Maybe it is just my used motor or my custom wiring harness, but that is my experience
In the end, should be no need for different switches
Most helpful as ever, the links to the pull switch is really helpful.
BTW, I have the Kelvedon kit, does anybody happen to have the wiring diagram, the kit has been sitting on a shelf for a while and now I cant find the wiring.
Thanks much
Nick
Veg
I have the Spyder kit installed on my Plus 2 restoration project. If raising and lowering the pods are controlled by sidelight operation (as suggested by Spyder), why would they retract when switching from high to low beam?
Spyder’s instructions may be different than what was provided in the kit I got from Kelvedon, so I don’t know about that specifically- but I’d like to be able to run the sidelights by themselves as sometimes just that extra little bit of conspicuity is good to have without the need to go full-frogeye. And I’m not quite clever-enough to have realised the thing about providing earth rather than power, which in hindsight may save me having to manually switch the motor*. I’ll have to experiment with that once I get some related electrical gremlins sorted.
*And of course freeing-up that switch on the dashboard means that I can use it for some other purpose later…maybe for some gadget that would make James Bond proud or envious? Any suggestions?
