Upholstery
Firstly I am full of admiration for the members of this forum and the advice given by them. Keep it up.
I have a 1973 Plus 2S 130/5 which I would like to repair the front seats. Some of the inserts have split at the seams . Can anyone advise whether the original materials are still available and where it could be obtained? The balance of the upholstery is still very good and thus would like to replicate as close as possible.
Thanks in advance.
the materials are available…I had mine done 2 years ago and they are exactly the same as the original…I belive the material is or german origin but other than that I’m afraid I cant help and the trimmer I used had nipped off to Oz to start a new life!!!
sorry I cant be of more help…I just wanted to assure you that you can get the materials youre after
G
Hi Terry,
Peter Day will know as he uses the correct insert material on his restorations and I believe Paul Matty can source it too.
Hope this helps,
Si
Thanks for the info, I will contact Paul Matty.
Terry.
Si,
Could you give me the contact for Peter Day as I have tried Paul Matty and he cannot help.
Terry Posma.
Hi Terry,
Sorry for not replying sooner. I’ll send you the number in a PM as I’m not sure whether it’s his home telephone and he wouldn’t thank me for posting it.
Best wishes,
Si
Terry,
You may also try woolies-trim.co.uk/. They might be able to help.
Hamish.
