Several years ago I purchased a set of 5 alloy KO wheels from Spyder Engineering. They were manufactured by Two Gates Wheels. I believe they are now out of business and were located in Birmingham.
I saw a posting on a Marcos web site that Two Gates alloy wheels for the Marcos were developing cracks and failing. Has anyone heard of or experienced any smilar problems with +2 Two Gates KO Alloy Wheels?
all alloys are prone to stress cracking with age, I’m not sure what the wheels you’ve got are like, or what you intend to do with them. If you are after a fun road car that you wont push to extremes, I’d visually check them for cracks after cleaning, do the “ring test” (hit them with a mallet firmly on the rim and listen for a dull sound, if they all ring true then tube em and use em!! If you are after a track day motor that you will drive like you stole, I’d only fit new wheels, that really leaves you with min ilites
hope this helps
(you could always have them x rayed, but where to get this done I do not know)
I purchased the “Two gates” alloy wheels new from Spyder. The “two gates” wheels that were cracking on Marcos cars,I beleive, were also new. Possible reproductions of original Marcos alloys.
I see Minilite makes 14 x 6J KO alloys. If I suspect a problem I will get a set of Minilites.
nice wheels! try spyder, ask if they have had a problem and if the manufacturer is still around.If they are, chances are they will crack test the rims for you gratis if they are un used.
I prefer supalites to minilights, however thier sales office are about as helpful as a chocolate teapot, the conversation(via email ) went as follows " Hi are you able to supply 5 1/2"x13 rims with 100mm back space to the lotus knock on 5 peg drive pattern, if so who can i order them from? thanks Mark"
reply?
I remember Two Gates Wheels from when they tried to get business from Ford.
The foundry and machine shop was in Telford, and the toolroom that made the dies were in Two Gates Tamworth.
The Tamworth site is now a housing estate ? which seems to be the way industry is going in Britain.
I just searched Google and found references to Deloitte & Touche, so I guess they no longer exist.
This does look like they have gone under; in my earlier post I said that I believed that Miniltes were “currently” cast by Two Gates- I should maybe have said “six months ago”…
looks tom me like its an issue with the particular wheel used on the Marcos, it could be a design fault in the wheel or defective casting process, theimplication is to fit a different type of rim which leads me to believe the problem lies with that style of rim.
I rekon you have nothing to worry about, but just my opinion. The pedal box pivot issue is more of a concern, thats what mine looked like!! I had a new stainless one machined up.
