twink flywheel needed
Need a four bolt flywheel for twincam…anyone got one? I have a 1500 cortina one would this be useable
The Cortina flywheel could be used but it takes a smaller clutch…7.5" from memory and the Lotus takes a 8.0" I suppose you could have the flywheel redrilled to accept the larger pressure plate although I’m not sure this is ideal.
You could also use the Cortina/Escort clutch but I think this involves modifying the release bearing carrier, not to sure now…I did one years ago but I think I fitted an Escort clutch and release bearing.
If money is no object, I bought a new Fidanaza lightweight flywheel on eBay a few years ago (at less than retail). As I recall it’s about 6 pounds lighter than the stock flywheel. Driveability in the city is not adversely affected. I’ve been happy with it.
aluminumflywheels.com
Gary
'71 Elan Sprint
Miami, FL
i have a 4 bolt flywheel u can fit a 6.5 clutch without modification.
where r u
