Hi There
I am in need of the twin cam engines dimensions excluding ancillaries. I would measure mine, but it is dark and cold out and I need them now to order a boxed pallet. If anyone can help it would be much appreciated.
Many thanks!
Bernard
Hi There
Many thanks!
Bernard
When you say engine dimensions,has it a sump.head flywheel etc.???
and do you just need the height,width,length?
Yes, its sump head flywheel and clutch assembly, but I will add on a bit for luck. Just the height width and length would be great. If you have the weight I will pass that information on as well.
Many thanks
Berni
Berni,
My engine is currently on an engine stand and easy to measure, But the flywheel and clutch are not in place. Also, no intake manifold and carbs and no exhaust manifold.
Diminsions are: 22" long, 17"wide, 23" high. Add 4" for clutch and flywheel.
I would add 3" for crate sizing.
David - 72Sprint DHC
