Trim attaching
How are the trim panels that cover the wiring and heater at the center of the console and dash attached?
I have two cardboard pieces covered in black vinyl with no clips or holes or any sign of how they attach to the console / dash area.
Bob
Hi Bob
Any chance of some photos - not sure of the panels you refer to.
In the parts manual it is called a heater valance assembly. As previously stated, I have both parts, LH and RH, but they are “plain” with no brackets nor attachment holes or securing devices.
It appears that a bracket was used but I am uncertain by looking at the parts diagram.
Bob
The 'valances" are held in place by finish screws and washers that attach to the adjoining trim by sheet metal screw capture plates. The one exception is the front lower corner of the valance which srews directly into the fiberglass with finish screw and washer.
I have a Elan S3 coupe and the way I attach my valances was to use double sided trim tape that is use to hold exterior trim to the outside of cars. I used it along the bottom of the dash and used a screw with washer into fiberglass covering the heater stuff on each side. Be careful as the valance is breakable. I do not know how your +2 attaches but that is how I attached mine.
Sarto
crannyr
I assume the “capture plates” are mounted to the dash and the firewall foot well area.
Pictures?
Bob
I have tried to reply and forward pics twice without success. Email me at [email protected] and I can give you the pics and additional information
Rick
