I am wanting to have all the bright work on my Plus 2 re chromed.
am I better replacing those parts which are still available or is it still usually more cost effective to have parts re chromed?
I am think mainly about the spinners - can anyone advise on a likely replacement price versus typical cost to re profile (ears are lightly knocked) and re chrome?
The bumpers are another story and I guess I will have to have them re chromed
What about those horrid mazak lights - are they worth trying to get re chromed or do I have to bite the bullet
Finally I have heard good reports of Derby chrome plating - does anyone have first hand experience of this or any other UK firm worth approching?
Canât advise on plating costs but the man who restored my car used Derby plating because âthey were the best in the businessâ he said.
This was some 16 years ago and most of my chrome is still in great condition, with the exception of the rear bumper, which has some slight bubbling. I donât know what the condition of the parts were like before plating, but I know the rear bumper usually comes off worst in terms of corrosionâŚ
As far as the spinners are concerned, Paul Matty is doing them at a special offer at the moment - ?30.87 + VAT
Spinners normally work out at about 2/3 of new to have rechromed. Donât even bother about Zinc (Mazak) cast bits, Front/rear light clusters, etc. They pit for fun and will never rechrome well. Boot hinges are cheaper to buy new (Hillman Imp) and Petrol filler caps are readily available at reasonable prices whether lockable or not. Door window frames are worth rechroming as are the finishing strips on the +2 roof. Being brass they chrome well.
I had my door frames and roof rails chromed a couple of months back and they look great , cant remember the company who I used, but he was in Surrey and recommended by a work mate.
Both the rails and frames were brass, coming off a '69 S.
Derby Chrome highly regarded, not the cheapest, but extremely good. Iâm a member of a classic car luncheon club, mostly E types, XK 150 and Healeys. Several have used Derby and all sing their praises.
Mazak Mender. Tried to obtain some, their web site wouldnât work at the purchase stage, so gave up after some weeks of sending emails with no meaningful response. Another product is Lumiweld. It does work, but it is for the determined and patient.
Method. Have component stripped of all chrome nickel and copper. Small pits in Chrome usually result in much larger craters in the mazak immediately underneath. Get rotary sanding drum (about 6 inches dia) with sanding band around foam drum, place in drill stand and clean up all over. Take Dremel or similar and with a small spherically ended bit, clean up each crater until you can see only bright metal. Take rod of Lumiweld and with very small blowlamp (used for jewellery or in kitchen) heat up mazak where you need to repair. Mazak is âhot shortâ (it melts before there is any change in colour) keep prodding with the Lumiweld rod, it will melt first. Very carefully keep on applying heat until the mazak just begins to puddle and then you get a good bond between the lumiweld and the mazak. There is only 40 degrees C difference between melting points. And when mazak melts, it goes fast and it all falls into a big puddle on your workbench.
When completed, you will have something that looks a little like electric arc welding and it can then be shaped on the sanding drum. Take it to chrome plating shop, ask for a thick nickel coat and get them to clean up shape and finish at this time, followed by a final coat of nickel, polish and finally chrome.
Does it work? If youâve got a good bond, then YES. It chromes well. Is it easy? NO! Iâve done quite a bit now and I still reckon I cannot get better than 2 out of 3 successfully completed. And is it quick? Far from it. If I costed my time at 50p per hour, I still reckon it would be cheaper to buy Paul Mattyâs ?250 front sidelamps for my Plus 2. But it is fun to beat the system this way.
Freddie Whitelaw
1973 Plus 2 130/5
1968 Plus 2 convertible conversion
Well saw my name mentioned in this post ref the above subject so thought Iâd better give an update !!
Thanks to Tim Heinemann I now have a fantastic 3d scan of the aforementioned article and a PDF of the same as well as a CAD drawing, I / WE can never thank Tim enough for his input in this quest.
All of the mentioned files are with 2 different casting companies in China for evaluation and pricing. (very good I hear you say) But its not all good news as one of the companies who sounded VERY positive and helpful asked for a sample to do a final evaluation so I sent one and GUESS WHAT ?? Yep the postal system has Mislaid it somewhere between Kenmare and Beijing !!!
Still we have a tracking number so hopefully they will trace it and we can move forwards,
Sorry its taking so long but I swear I have about 100 emails in the âlotus lightsâ file but we plod on at a slow rate.
On a brighter side they should be considerably cheaper than those mentioned above IF I can ever get this task completed
Thatâs all the news I have for the present, other than there are some dash lettings left if anyone still needs some and also some 1/4 light window channels.
When they are gone they are gone as I have no plans for any more to be made of either at present.
