Hi, I would like any opinions on adjustable tilting lifts, Automech and CJ Autos have them on Ebay.
I have a Plus 2 with Spyder chassis and Sills in excellent condition, I would use tight fitting threaded bolts in the jacking points.
My garage has limited space so the lift would be left down and parked over, one concern is that I haven’t the width to use the winding handle supplied so I presume a socket would be O.K.
I couldn’t find the ones you mentioned but I did buy a garage lift through eBay this year, if you search on…
“Strongman Clifton Mobile 3T Home Garage Car Lift” you’ll find it.
It’s a top quality bit of kit, over-engineered for what I needed as it will lift 3 tonnes, I use it for an Elan and a Plus 2. It folds down flat so I always have one of them parked on it when not in use.
Hi Iain,
I am looking both the ‘Clifton’ and also the slightly lower priced ‘Montford’ Scissor from Strongman. Can you tell me please do you need starter ramps to get a +2 on the lift?
Also can you tell me is Strongman scissor lift directional?..In other words can you have the car reversed on the lift or must the engine end of the car ( the front) always be over the ram end of the lift due to the weight/centre of gravity?
Apologies for jumping in and the thread drift John!
No need for starter ramps, there is plenty of clearance to drive straight on.
The ramp is not directional, I use it both ways with no instability, in fact I sometimes use it to lift only one end if the car if I need to quickly look under one end, obviously you only use a low lift height and make sure to chock the wheels.
My main reason for choosing this lift was my limited roof height in the garage, as it stands I can get full lift and the car roof is still clear of the garage roof beams.
Thanks for that Iain.
That is very useful information particularly so about being the Strongman being non-directional. I have looked at other mid rise scissor lift makes which do specifically state that their lift is directional and must not be used reverse on.
I too have limited height, only 8ft, so I think I would just about get full height with a +2 on it.
Hi John
I have one of the tilting lifts you mention and find it is really good. Very easy to use and as you say you can just leave it underneath your car. I’m not sure if you can drive over it or not as I have only ever used it by sliding it under from the side, which can be done by lifting it on its side so you don’t need to have the full width of it to the side of your car.
David
Hi David, thanks for the info. I just think with the width of the Plus 2 and the lift needing to be at a wide setting in order to align with the sills I would run out of space between the car and the garage wall.
I now realise that you cannot drive onto them like a normal ramp. John
Hi again Iain,
Just a longshot but I was wondering if you had a photo of a +2 actually on your Strongman Clifton lift? It would be very interesting for me to see how it sits with regard to the position of the ramps and may help my decision making.
Don’t mind PM or on here whichever is easiest.
Thanks.
Ive just bought the Automotech Adjustable Tilting Lift for my S3 Elan diff change … which looks a really good bit of kit … & I wonder where is best to mount it ?
Obviously , it can be mounted inboard or outboard … & the sill is the natural choice … but the pad won`t quite reach the strongest corner point at the end of the sill … ?
When I rang Automotech , they didnt have any experience of it with Elans .... & I have thought about extending the mounting pad ( again Automotech couldnt help ) to reach the full length of the sill … which I think would be ideal , for spreading the load … ?
Maybe David or somebody can advise … I just like to keep the stress on the fibre glass body to a mimimum : )
Yeh , Ill get a picture ... my lift looks the same as Davids above … and the mounting pad length is about 500mm ( Ill check ) shorter than the cars overall sill length …
It`s probably not an issue … as it is a substantial mounting pad ( for spreading load ) anyway … & of course some of the weight is also being transferred to the 2 remaining wheels on the floor … but you do have the option to level the car when raised … so , a full length sill mount would be ideal I guess …
Iain, that looks tough. I’ll be helping my upgrading his garage after we finished installing the brake kit and dually wheels on the current Superduty project. I’ll let him check that one.
Hi all
I’ve been looking at the £400 tilting lift too. One question, hope you can help…
With my newly replaced stainless sill beams I’ve been wondering how to deal with the GRP that protrudes beyond the bottom of the sill. Would using a lift like this mean that the car would be resting on this, which sounds problematic.
Is the normal thing to fair back the GRP until it is flush with the metal sill which is sandwiched between? It’s only a mm or two here and there.
Ned
On my car the lip for the re-enforcement is above the floor level. So I lift the car via the floor, but very careful place a spreader that runs most the length between front wheel well wall and section sectionsjust in front of rear wheel as these are the strongest areas.
Ned, I had the same thought using my new QuickJack with the Plus 2. The QuickJack only allows the jacking pad/blocks to be placed 60” apart. The sill beams are slightly longer, and the jacking point tubes are approximately 63” apart.
I have made up two 2x8 boards that run the length of the sill beams. I cut down four carriage bolts to approximately 5 1/2” length and bolted them to the 2x8’s to provide four jacking pins that fit into the jacking point tubes. The 2x8 will rest securely on the QuickJack platform, and with the ~7” width the hope is there will be no tendency for the car to rock or bend the rocker area.
I used something similar to remove and reinstall the body on the frame. Then I used ~2” square aluminum tubing for the length of the rockers. That approach worked, but the tubing was not stable enough and I was concerned that the fibreglass rockers would crack.
Car is in the air on blocks right now, so I have not tried this new approach yet. Pretty sure it will work OK though.
A word of caution. The Plus 2 can be lifted from the floor, but be very careful. The fibreglass is very thin, and if the lifting force is close to any vertical bulkheads they can easily crack in compression. After suffering some damage with other jacking methods, I did lift the car with conventional jacks in this way using four approximately 12” square plywood pads to spread the load over the thin floor, but never really liked the setup.
When I damaged the shell, the issue was uneven lifting side to side or over the length of the car. My cautionary advice, no matter how you intend to lift the car, is to make sure it is raised and lowered evenly. The QuickJack or similar make this easier for sure, but watch out for the details. In particular the QuickJack has a lever actuated stop at about half way up. In my case one side locked while the other side kept moving. The uneven lifting force caused extensive damage that I have just finished repairing. Totally my fault and embarrassed to mention it, but hopefully helps someone else out.
I have attached a pretty lousy picture of the 2x8’s. They are kind of inaccessible right now as we enjoy a Polar Vortex and -40 degree weather. Hopefully good enough to get the idea. The plywood pads on the bottom are intended to keep them securely located in the QuickJack platform. The 3/8” carriage bolt nuts are a combination of a coupling nut and a Nyloc, which perfectly spaces the 2x8 off of the sill fibreglass. The boards are marked left and right, as in my case the jacking point spacing differed by about a 1/4”.
Just some ideas. Grinding down the ~1/4” intermittent fibreglass lip so a 2x8 or similar board rests on the steel should work OK as well. Mbell’s method sounds OK as well.
For reference, here is a link to the QuickJack site. Although some of the other lifts differ, I think the issues involving lifting the Plus 2 are pretty similar.
Really helpful advice! Many thanks. I will do exactly as you suggest on the sill boards with the pins locating in the jacking points. Great idea!
Best regards
Ned
