Does anyone know where this is located and what it looks like?
The only thing I can find behind the dash (without removing it) that may be it is a bakelight looking strip thing with wires going to it that is screwed to the pasenger side of the heater… Is this it?
The problem is that the current consumed by the headlights is near the tolerance limit of the cut out. Even fitting a set of uprated instrument lamps can do this. (i.e. 4w instead of 2w)
I had this problem when I fitted uprated headlight lamps. What an eejit I was. Headlights cut out pretty quickly and as luck would have it, going into a corned in the pitch dark! A bit concerning to say the least. (I had uprated the wiring BTW).
Fitted a couple of relays to do the switching for me. Now the cut out only sees the far smaller current used by the relay coils. Problem solved.
Surely a device that can turn off your headlights without any warning is really bad. Is it there to prevent fire? If so, isn’t that actually a very dangerous bodge? The relay solution sounds like a sensible upgrade, and if fitted to supply current from a low impedance path to the battery will probably give you much brighter headlights than changing bulbs over.
While putting the headlights on a relay is a good idea, I suspect your problem is either:
Loose connection.
Use of higher-amperage than design components.
A loose connection adds to the current draw of the circuit by wasting energy in arcing the loose gap. The headlights will be brighter at less current draw with good connections.
Remember also that whatever the cutout did will be pretty much completely defeated by a relay system. Not that this is a bad thing…
The simple concept of the relay is to bring the hot power as close as possible to the headlights before switching it. A heavy guage wire runs to somewhere between the headlights, another heavy guage wire runs to the headlights, and a relay is used to make the connection between the two. This relay needs to be suitable for the current draw of the components, and you need two circuits on the headlamp side only, one each for low and high beam. The original circuit (absent connection to the headlamps) can then be used to activate the relay (and taillamps and running lights).
Note that if not done carefully, this will have the negative effect of creating an unswitched source of hot power for short circuits and the ensuing electrical fires near the headlights. No lamp cord, please!
If you want a new cutout I got mine from Paul Matty. Having said that I’ve not driven the car in the dark since the lights cut out on me (very scary indeed) so the idea of an in line fuse to replace the cut out sounds pretty good to me.
Thanks Simon, I had heard they can be bought new, although I also heard they were quite expensive…?
I’ll check the circuit first and see if I can find any weak spots, and see what the headlight bulb rating is. If that’s all ok then I may use Matt’s suggestion of a fuse.
Robbie, from my ‘O’ level physics (taken a very long time ago) I think the equation is Power(in watts)=Voltage(in volts) X Current(in amps). So therefore if the lights take 96 watts(for example) then with 12 volts the current draw would be 8 amps. I’m sure some of our fellow ‘forumers’ will be able to more detail as to how much allowance should be made and what the true power consumption of the lights is etc. Another thought might be to look in the workshop manual for earlier cars which I believe didn’t have the thermal cutout and see what fuses were used in their case.
I checked all the wiring and cleaned it to try and stop the lights cutting out. I discovered I have H4 60/55W bulbs fitted. Is this too high for the original wiring and would this be the cause of the cutout operating?
60/55s would seem ok. That’s what mine had fitted.
Another advantage of using relays (apart from lessening the chance of a cut out) is brighter lights. You can run a really beefy power cable to the relays and if you like, a beefy cable from the relay to the headlights. That way you reduce the voltage drop at the headlight - thus brighter lights. (of course, remember to beef up the earth conections as well).
The secret of bright lights is voltage!
Also because you are now using relays and beefier cables, you can fit higher wattage bulbs in the headlights. There will be no cut out problems because all the cut out will ‘see’ is the relay coil current.
Just about any automotive parts supplier can sell you a thermal self resetting circuit breaker. At worst case you headlights will flash as the CB heats and cools. This what I believe modern cars do as well, safety, but usability.
