Question – how do you remove the tail housing on a T9 transmission?
I have removed the bolts holding to tail housing to the main case. However, I can’t remove the housing because of interference of the shift arm, located at the end of the gear selector shaft, with the tail housing. I assume one has to remove the shift arm, but I don’t see how to accomplish this.
There is a split pin that is driven through the shift arm right through the shift shaft. You should use a pin punch as it makes it easier but isn’t nessessary if the punch is a good fit.
