HI everyone,
I have been reviewing my dash harness installation that I’ve been trying to sort for about forever. (first post “Wired and Tired” circa Aug. 21) This is part d’eux. My car is a 71 Lotus Elan Plus 2S130 “early”, Big valve, 3 fuse box, alternator based, Federal Model. It is as built, no mods except a paint job prior to my ownership. Oops I forgot one item, Serial number 0179N built Aug 71.
Given that excessive intro I was hopeful when I bought my harness from British Wiring they would send me a harness similar to the car on-hand. (Puchased Harness p.n’s 1868, 1870 and 869 for the dash, main and body harness respectively). I was assured by the website as well as on-site personnel, that I would be “good to go”.
Its not good, and I’m going nowhere. Many issues… “Houston”- get a fresh pencil…
The old wiring followed the drawing specs as outlined in the shop manual perfectly well.
However, the harness received does not track with the print. Particularly in the areas of the hazard switch, DB10 Relay box, directional switch. I have been studying this for hours and days, trying to make sense of what is wrong with the as-received harness. The indicator and hazard relay sockets and connections came hard wired from British wiring. I followed this wiring and it did not match with my wiring diagram, it finally became clear what happened.
Contrary to the website description, British wiring used the Plus 2S non-federal Spec when they built the harness! Unfortunately this is not a simple simple fix in my view.
I could possibly follow the loom and use already in place non-federal spec wires. But this has a trickle down affect on other components.(hazard switch differences, directional switch connectons etc) The non-federal spec for one thing, has no DB10 Relay box. So… If I use LGN Light green/brown wire from the indicator flasher unit to the indicator switch, according to the non-federal spec, I won’t have anything to go to pin 1 of the DB10. I also don’t know if I should add a wire or not connect one to the DB10. My car has a 5 lug hazard switch with different wires connecting it. The BW non-federal harness uses a 6 lug switch and again wires and color codes don’t line up with the Federal spec. The functionality of the circuit has changed significantly. I am actually very frustrated given all the hours involved sorting this vendor’s product. I have written to them as well.
(I was considering switching to and Autospark harness but I don’t know if Autospark makes their own harnesses or buys them from British wiring, -the vendor part numbers used are identical. )
Thanks very much for your suggestions. Photo Extracts below.
Federal version (my Plus 2), should be the first photo (with DB10)
The harness was built to the second photo it seems.
Thanks for your comments and suggestions…it is appreciated. Time for a cold beer, but I guess that depends on who wired up the fridge…
