“There should have been two white wires instead of just one on these two ignition feed terminals — one feeding one of the two fuses, and the other feeding the ignition coil via the tachometer.”
John, why do you say that? If that were true, then the accessories would function only when the key was in position II or III and you don’t want anything except the starter and the ignition working when the key is in position III.
“…a feed goes to the tachometer and connects to one of three connectors on a recessed brown plastic thingy (voltage stabiliser??) at the rear of the tacho.”
The “recessed brown plastic thingy” is an insulated board that holds the tach connections. It’s part of the tach, not the voltage stabilizer.
“Another white wire leaves that same brown plastic thing and goes to the coil…”
That is the same as the white wire going in. The two connections are on either end of a short white wire inside the tach. The wire inside the tach loops around a magnetic pickup and exits right next to where it goes in. One connection is male and the other is female. That way, if you want to run you car while the tach is being repaired, you just connect the two white wires to each other instead of running them through the tach.
“…and it has seriously overheated — it melted its insulating shroud. The melted plastic cemented the electrical connections together.”
OK, now we’re getting somewhere. You’ve got a dead short in the wire that goes from the tach to the coil. The short may be the result of the connection at the coil touching ground, or it may be the result of the wire itself touching ground between the tach and the coil. I’m surprised that the white wire from the bullet connection to the tach is OK. I can just about guarantee that the little white wire that I was talking about that is in the tach is melted also. You’ll have to remove the tach and have a look. A new one can be fabricated if you can salvage the male and female connections. Meanwhile, as I suggested above, connect the two white wires to each other, bypassing the tach while you attempt to solve this problem.
“My wiring diagram shows four green wires connecting to the voltage stabiliser in the tachometer.”
The voltage stabilizer in not in the tachometer. It is mounted on the rear of the tach or the rear of the speedometer, I can’t remember which. (I have since moved mine to another location.)
“I have found three wires — two white and one green — connected to the recessed brown plastic thing. Is this the voltage stabiliser?”
Again, the “recessed brown plastic thing” is the circuit board that holds the tach connections. It’s part of the tach, not the voltage stabilizer. We’ve already been over the two white wires. The green wire is 12V coming in to power the tach.
“Why does the feed to the ignition coil come from it?”
I think I’ve already gone over that.
“What happen when it fails?”
No power to the coil.
“Any ideas why the output to the ignition coil should overheat?”
Dead short somewhere between the ignition switch and the coil.
Have you taken my suggestion and looked at the “Gremlin” post? Good luck.
Frank Howard
'71 S4 SE
Minnesota
