New here, just wanted to ask a question about Sprints.
Can someone tell me when they first entered production? I see on this website it mentions 1971 except I see a lot of other references on the Web mentioning 1970? Was it different for DHC’s versus Coupes etc?
Also I see a few Sprints with raised bumps in the bonnet I gather to clear the Carbs but I’ve also seen some without these. What’s the situation there?
Officially the Sprint was introduced early 71 (Feb I think) but its generally agreed that Lotus and their dealers who had unsold S4’s changed these S4’s into Sprints, the debate carries on to weather these are Sprints or not.Sprints are just S4’s with B.V. engines and a few other minor changes.
As far as I understand the bonnets, Lotus just used up the bulged bonnets (which were for Stromburg cars)
Lotus had gone back to Webers/Deloto’s and were not going to waste the bonnets.
Aha thanks. I’ve been looking at a Car advertised as a Sprint from March 1970 with a very low single digit engine number. 000xC. I would gather this potentially is one of these converted Sprints. I gather it becomes very difficult to know what you’re looking at to verify authenticity. Is there anything else I can look for?
If it is an “official Sprint” (U.K. spec) the engine number will start with the letter “N” of course an engine can be changed at any time.
The Sprints had the Big Valve engine with a B.V. ribbed cam cover (also can be changed)
The raised casting near no 1 plug on the head should also have an “N” stamped on it (U.K. spec)
The diff has a strenghening bracket at the top where it mounts.It is also fitted with a 3.7 diff as standard (not sure what the S4’s had)
The seats in all the Sprints I have seen do not tip up, they only slide back and front. (actually I took the extra brackets of my Sprint so mine do tip up)
Sprints were available in one colour but most cars have been resprayed by now anyway.
As far as I know all U.K. Sprints had Deloto carbs not webers (could be wrong though)
Cant think of any more differences at the moment.
The number you have mentioned sounds like part of the VIN - not the engine number. See the link https://lotuselan.net/lotus-elan/ (on the home page of the forums). As you will see - Sprints weren’t released until 1971 and the “C” for instance suggests the car is a S4 dhc built for domestic (UK) market
Engine no’s are a single alpha character followed by numeric id - e.g. C12345. The alpha prefix identifies the engine config (cams, carb’s, head) and target car - there are about 24 variants and as Brian said an original Elan Sprint engine no. for UK was prefixed N.
After 30+ years though now, very few cars are really original and a lot of S4’s have become “Sprint like”.
OK it sounds like the nth S4 DHC produced on the new numbering scheme. Would be interesting to find out if it was a Lotus modified/Dealer modified or home modified car but guess I’ll never know.
hmm Guys can you help me out here? I have a VIN number and I’m confused as to what the Car is now.
450006C
All this says to me is that the car is a DHC. The number past 45 I can’t work out at all, it should be a series 3?! The C from the list on here only makes sense if the car is a 1970. The car was first registered in the UK in March 70…!!!
“As far as I know all U.K. Sprints had Deloto carbs not webers (could be wrong though)”
My '71 Sprint had Webers. It was many years ago and was a factory fresh original car in Gold Leaf colours.
There are quite a few fake Sprints around but I would argue that if it is all Sprint spec’ does it matter? … Unless of course you are paying a price premium or are someone who worries about such things
[quote=“LL”]
450006C
All this says to me is that the car is a DHC. The number past 45 I can’t work out at all, it should be a series 3?! The C from the list on here only makes sense if the car is a 1970. The car was first registered in the UK in March 70…!!! quote]
Does it have a chassis plate?
Why do you say its a series 3? does it have S3 or S4 rear lights?
45 is a drophead
The last four digits should be the chassis number…0006
The C is an Elan STD Convertible
Lotus changed the chassis numbering system in 1970 and the mysteries of anything to do with Lotus records are well known, it all adds to the legends and myths of Lotus ownership.
If you think its qenuine car buy it and enjoy
OK it seems the VIN on the V5 is not quite right, the VIN on the car is 7001010006C, so that now makes sense. The Sprint/non-Sprint issue is another topic altogether… Cheers.
The Sprint concept was announced in October 1970 at the Motor Show. The Sprint started to be manufactured in January 1971 for release in February 1971. Therefore only cars with unit identification plates starting with 7101 can be considered true Sprints.
The consensus is that the last Sprints were manufactured in February 1973, 73020899 being the final DHC. However, it appears that they continued to be listed and available up to August 1973. Certainly I have seen some Sprints on the M registration plate, indicating they were registered after 1 August 1973. In other words, there continued to be stock of cars from the dealers for some time after final manufacture. I do know of one Sprint with a unit number starting 7303, just to add the usual dash of Lotus factory confusion into this!
From your unit ID, LL, you appear to have an S4 made in January 1970, production batch 01, chassis number 0006, making it obviously one of the first Elans to use the new numbering system.
Thanks everyone. The car I believe is indeed an S4 DHC. At some point it was converted to Sprint spec. I bought the car anyway as even though I am a purist my wife who is not was in love with the bloody thing and to be honest it was at non-Sprint prices. Happy to live with that.
Got to drive it for the first time today and can’t believe how advanced the chassis is compared to contemporary vehicles. The grip and the balance is astonishing compared to most modern cars. I drive an M3 CSL every day and I swear this little Elan would keep up with it on challenging roads. Quite an eye opener. I have several old MG’s and Healeys and the Elan would wipe the floor with the lot of them! Incidentally one of the guys who works for me has a S2 Elise and this seems better put together, almost as quick to 70/80mph, less rattles and a lot nicer driving position! My business partner has a S2 M100 Elan and this little car wipes the floor with it.
I should post a pic up at some point, hope our little converted Sprint doesn’t upset the majority, I know how particular some people are with Classics but even if it isn’t original it’s still a brilliant bit of gear!
Congratulations on getting your car and joining the group, lots of info available here (and not too many disagreements)
As a matter of interest, does your car have a Lotus or Spyder chassis ?(and I am NOT knocking Spyder chassis’s)
Couple of tips:
carry a fire extinguisher (good insurance)
join Club Lotus
Brian.
Hello LL,
likewise welcome aboard!
What a glowing report on you new Elan, especially the comparisons with those other very highly regarded cars.
The red mist is coming down, you’ve spurred me on to take my S4 out for a thrash this evening.
Like “Brian” has said this is a great newsgroup there are a lot of very kind and experienced members always happy to share their experience or provide help in some way.
All the best.
Lotus used to = kit car. If it’s a Sprint built at the factory or a “Sprint” built by some guy, who cares? The +2 was a kit car. Drive yours fast, be safe and have fun.
Just as a footnote on the S4/Sprint debate, my car was originally manufactured in 1970 as an S4 on Strombergs but before it was sold in 1971 it was converted to Sprint spec by the factory (webers, big valve, diff reinforcement etc etc) and badged as a Sprint but left in a single colour with the Stromberg bonnet bulge. I was sceptical when I bought the car until I saw a letter from the factory confirming all this had happened to my car. My understanding is that they had a load of unsold S4’s hanging around which they converted to Sprints so that they could sell them.
