When assembling a fixed splined shaft into a splined hub flange should I use a copper anti seize?
It is a splined fit with no key or taper.
Bob
Bob
Depends on operating temperature and environment. IF not to hot or to heavily loaded I would use loctite. i would use an anti sieze if operating above loctite melt temperatures or load stresses above what loctite can carry.
