Spark plugs
Hi all, just about to do a service on the Plus 2 and want to know what plugs people are using. I usually use NGK plugs but am open to suggestions?
Al Cowan
I use Bosch W7DC as they have a suitable heat range for normal road use with a very standard engine specification. I like the Bosch plugs because the thread form is very smooth and unlikely to damage the cylinder head. You have not said anything about the state of tune of your engine. That and your intended usage will greatly influence the proper choice of heat range.
hi
i have 2 elan +2’s 4speed 130s and 5 speed130s both big valve
i use ngk bp7es in both with no problems hope this helps
stuart
Sorry boys, it is a 1972 Plus 2 S130. Engine is bog stock!
Al Cowan
CHAMPION N9YRC
STEVE BECKER
