In light of the recent thread about Spax shocks breaking at the top mounting eyelet, I decided to purchase Koni shocks. While they are for a TVR they are coil over units similar to those used on the Elans.
I noticed on the old set of Konis that I removed from the car that there was no threaded portion of the rod past the eyelet body. The now units have extended threads and there are quite a few that continue past the eyelet body.
I removed one “eyelet” and found it was fully threaded on the shaft making the exposed threads unavoidable.
Would anyone consider this a potential area for breakage as the thread exposed will act as a stress riser?
Was this the mechanism that caused the Spax failures?
Are you able to post up a picture of your new Koni struts. I would like to see how similar they are to the correct ones for an Elan. I have made various enquiries recently, and Koni no longer make shocks for the Elan front.
I know that the TVR Koni no. 80 - 2365 is a TVR only part. If you have the Koni number for the Elan I will contact the person who sold me the shocks to see if he has any in stock for the Elan. Koni is placing many of these “classic” shocks on special order. I was told that the Koni shocks I purchased were new old stock. Mfg. date 2007.
If the group wanted a quantity maybe they could be special ordered. I believe that special order means the distributor must order a minimum quantity of one P/N of shock.
I’m just a bit puzzled here. Lotus Elan shocks don’t have a top eye do they, also on these shocks there’s no provision for the anti roll bar fixing. I’m not really sure what it is your asking.
