s3 door card attachment
Sorry, still learning about S3 doors here :slight_smile:. Is the door card attached via pop in clips at only the three
locations I pointed to?
I’m assuming any attachments forward of this is through the screws that hold the kick plate on, correct?
What is the purpose of the circled hole?
Greg,
My doors are at the paint shop, but my door cards are at home w/ me. You are correct about the snap-caps go where the arrowed holes are and anything farther forward are done through the kick plate. The location you have circled, I have a finishing washer on the vinyl on the door card indicating to me the location of an oval headed screw.
Later cars do not have the kick plates, but have carpeted portion of the door card there and they simply have more snap-caps between the door and the card.
Thanks Roger, that helps!
My 67 S3 has snaps front, rear and bottom of door card
Paul, does it have the metal kick panel?
