S3 air box seal
Any one got the original air box to back plate seal as fitted to a 1 2 or S3 elan lost mine and need to get a replacement seal, photo would be helpful
I used rubber ‘U’ channel from Car Builder Solutions:
cbsonline.co.uk/15-x-55-rubb … u4-7-p.asp
I’m sure this can be bought from many sources.
S2 owner here, I have just replaced the weber airbox seal on my elan. I found that the ideal rubber seal could be sourced from the early Toyota corolla (any of the very early K series engine’s) tappet cover seal. The seal almost fitted straight on, but needed a small section removed to make a snug fit, (Slightly too large) the rubber gasket material can be cut with sharp blade in your Stanley knife & easily rejoined with super glue. The best part was the cost… about $20.00AU at the local Repco parts store. It is worth checking this out.
Col
Thanks Brian & Col for the info
